PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Upgrade for less than $200?
  2. help chosing the right mrev
  3. Engine experts?
  4. Top Secret Replica (automotivemods)
  5. SES, Car shutting off...
  6. Ichiba or Megan
  7. jet performance chip
  8. Double-punch technique?
  9. 3 dynos, like some feedback or ideas.
  10. New tech at Creative Autoworks
  11. Intake hlep..
  12. sedan sound to coupe
  13. Dyno comparison: high-flow cats vs. test pipes
  14. 04 OEM G35 coupe's exhuast weight
  15. cobalt ss supercharged
  16. better intake
  17. The DYNO thread
  18. Oil and Oil filter help
  19. Aftermarket Radiator Hoses......
  20. EGT sensor?
  21. Recommended Service
  22. Oil temp and better cooling
  23. Quick Question
  24. HKS DLI II Ignition Amplifier Installed
  25. Underdrive Pulley sets off ebay?
  26. Engine sounds like a buzzsaw?!
  27. who has a modified engine cover?
  28. Check engine Light
  29. Where can I find an oil filter spacer (for a cooler) that will fit the sedan?
  30. Optima Dry Cell batteries?
  31. Gas gauge is actin wierd!!!!
  32. Does anyone have specific knowledge about the Mobil 1 oil filter?
  33. What kind of plenum setup...please help!?
  34. How to tell if what I have is MREV2 or MREV+
  35. High Flow Cat Question
  36. Nitrous
  37. OIL change question
  38. Performance Radiators
  39. V-8 G35
  40. Help!Checked My Oil.
  41. oil filter question.
  42. Installed my Injen CAI and I'm Having Issues....NEED HELP
  43. 60k service
  44. Fast ? about the stupid dipstick!
  45. I Am Pissed Off Please Help
  46. UTEC deals around OC or LA area in So Cal?
  47. Hot Starter, Car wont start
  48. TT experts, input needed. Will test pipes rasp at all on a Twin Turbo G35?
  49. Grounding Wire Kit
  50. How effective are supplemental oil coolers?
  51. What are the benefits or consequences of using a colder plug N/A?
  52. THIS or THAT?
  53. im really confused
  54. So...I powdercoated my Crawford Plenum
  55. Underdrive pulleys
  56. SES/higher RPM's after cleaning throtle body
  57. what is the stock size fuel injector?
  58. Turbocharger Shootout
  59. want some more hp!
  60. SAFC II on stock car
  61. How to disconnect the battery
  62. wtb a pop charger for coupe
  63. 54k miles what oil to use??
  64. *POLL* What color to paint?
  65. strange clicking under 20mph...
  66. car jerks when music is loud
  67. Anyone polish their own OEM upper plenum?
  68. Please help! Auto Motor on a Manual Car?
  69. cylinder 4
  70. NGK Iridium Plugs
  71. Additional tach / rev light
  72. Fumoto Drain Valve - Factory crush washer or not?
  73. Engine cover question - please help
  74. 1st oil change?
  75. mods to beat an s2000?
  76. engine stalling on 2004 coupe w/ less than 25k?
  77. I need help finding the plastic engine cover (under bottom bumper)
  78. I need help in disconnecting ignition coil connectors
  79. First oil change
  80. Speed?
  81. low rpms/stall like sound after mid pipe install
  82. oil in spark plugs
  83. Sending Oil for Lab Results? Anyone do it?
  84. Replacing pulleys
  85. Kinetix ssv VS MD Spacer
  86. Torque
  87. the syn myth
  88. Is the VDC disable button exactly the same as the Yaw sensor switch mod?
  89. Non-Revup + MREV+
  90. Mod bug hit.what to do next?
  91. Does ur G make a "click" sound when u back in reverse
  92. Autozone special: Oil
  93. MREV2 with 5/16 spacer installed with Dyno
  94. Finally Gave up
  95. Metal "click" noise when shifting into 5th gear (2005 6mt)
  96. Ecu
  97. Stillen Stage 1 SC?
  98. Mobil 1 Oil Filter
  99. Enhance the engine tone?
  100. what color to get?
