PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Where else to get colored fluid caps?
  2. How is the car get grounded?
  3. Need Help My Transmission Went Out
  4. HP Guess
  5. 2jz swap
  6. Anyone know about pulse plugs.
  7. stillen engine damper install help
  8. OEM oil filter is very poor quality :(
  9. Engine dress up question..
  10. Engine Turns over but won't Start.
  11. VQ35DE engine modeling
  12. 2004 G35 ECU Question?
  13. Octane Level For Gas
  14. went for oil change
  15. car feels like its lagging!!!?
  16. Engine sounds related to: bore? stroke?
  17. My car would not start today
  18. Is Amsoil XLF much worse than Amsoil ASL?
  19. 50k Miles Tuneup/Service - stuff to get done
  20. HP #'s on Stroked G35 blocks?
  21. AirBag light on and flashing...
  22. ASK : Quiet setting for G?
  23. Help me please any ideas?
  24. SOLID Motor mounts
  25. Premimum maintence worth it?
  26. RE-build engine question
  27. Cold Air Intake
  28. Ecu reflash
  29. Car starting problem
  30. Timing chain tensioner guides
  31. Is it easy for a newbie to install a 5/16 spacer
  32. Nismo or Stillen exhaust
  33. help with e-manage ultimate
  34. How much engine ping is considered normal?
  35. problem taking off the crush washer????
  36. Afc????
  37. aem intake water bypass valve
  38. How long should I wait before I start modifying my car?
  39. Spark Plugs with Oil Consumption Issues (see pics)
  40. Highest boost on stock block?
  41. Ses 1147
  42. HELP! I just spilled diet coke on my manual transmission
  43. replacing Fuel filter....
  44. Greddy Twin Turbo, AAM ECU Flash or Utec?
  45. spark plugs help
  46. Yay for me! Did my 1st oil change...
  47. anyone got ticket for having test pipe in CA?
  48. Is this Popcharger for G35?
  49. extending the tips
  50. Cleaning MAF need some help
  51. vdc and slip light
  52. Which Engine Oil do you guys use
  53. Stillen Z-Tube intake or 5/16 plenum spacer?
  54. tomei headers - emissions legal??
  55. arc radiator on a g35.. fitment??
  56. Exhaust suggestions
  57. Unburnt Gasoline in exhaust?
  58. wierd key problem
  59. Unburnt gasoline in exhaust?
  60. mrev2 on a 04 coupe
  61. why gas milage to low?
  62. anbody hear this sound...
  63. Car just shut down...
  64. G35 Purchasing.. Oil Consumption Issue...
  65. CEL question
  66. Oil change??? recommended oil (Mobil1), filter, interval, dealer/shop, price
  67. quick question about the "changeover"
  68. 04 Plenum Spacer
  69. HKS Hi-Power exhaust...good for daily driving?
  70. Ok this isn't normal..why is my fan
  71. questions about plenum spacers
  72. OBDII scanner recommendations
  73. Need Help Asap!!!!
  74. My Spacer Has Issues!
  75. Engine Oil: What Kind do you use?
  76. DIFFERENT ISSUE FROM OTHERS - VDC,Slip, SES lights & Trouble starting
  77. Best Bolt on Turbo kit.....
  78. HKS Camshafts for Non Rev-up VQ35DE (+32whp and +23lb-ft for FI)
  79. jacking the sedan
  80. Which Stroker?
  81. Trying to fix my exhaust setup :(
  82. Bolt Ons + Reflash=300whp
  83. Fact Or Fiction?
  84. Opinons - will I run lean with a plenum spacer and a FI exhaust?
  85. G35 Air Filter
  86. tension belt snapped...
  87. Consult II alternate
  88. what are the differences in all the G engines ?
  89. engine code..1st 0507, 2nd 1211, and now 2301
  90. Burning oil on an 03 going to dealership
  91. gas millage
  92. 911:help - Removing Valve Cover
  93. agency power pulley set???
  94. which spark plugs do you recommend?
  95. radiator hoses collapse when car is cold
  96. Ebay knock off pulley kit
  97. 05 G35 Sedan Oil
  98. oil pressure guage
  99. OBDII Code P0340
  100. Valve adjustment needed?
