- Why Does My Car Keep Dying?!
- Engine pinging has become an issue as of late.
- spacers
- Chips
- 350evo SSK or 5/16 iso thermal spacer?
- Anyone Teflon coated their Intake?
- Brand new engine knocking at 300 miles!
- power steering question
- afe intake for the G. Does anyone have this?
- What short shifter is this??
- engine oil
- Ok....i think i have a problem.
- Question on OEM Infiniti radiator cap and aftermarket cap
- UR Pulley Install Q
- After I/H/E what's next?
- Sound clip wanted: stock coupe exhaust w/ no cats
- After I/H/E whta's next?
- weird engine sound
- Simple Engine Question
- how long has your battery lasted ?
- 2J Swapped 350Z.....
- engine help?
- Coolant Leak question
- Grinding noise when starting the engine
- steering vibration of my car, help guys??
- Recommended oil for '04 G35 Sedan?
- DTC P1229, elaborate
- Annoying problem when i start the car
- HELP!! chattering sound coming from ENGINE
- V8 conversion for a G coupe....
- Vehicle won't rev above 2200rpm, dealer couldn't replicate
- Unusual engine rev when braking
- MDE Iso Thermal 5/16 Spacer 350z -> G35c Fitment
- 2003 G35 Recall for Cam Sensor... But it occured already..
- autosport harness is this a good deal
- Is that a catch can, or are you just happy to see me?
- Check engine light on after MREV2
- Idler Pulley Removal Mod with Pics
- Bad water pump? '03 sedan
- Service Engine Soon?!
- Has anyone had this problem??
- Mobil1 Extended Performance 15000 mile gar.
- 5k miles on royal purple
- FI Sedan with rev limit problem...
- Finished Engine Project :)
- skunk2 spacers
- Oil Pump?
- the NOT ANOTHER pulley thread.
- Heater doesn't work while idle
- Throttle flutter - G won't go
- how loud are these parts?
- Hard to Turn Steering Wheel
- Hmm jwt with z tube or fujita??
- What's the best oil pan/spacer?
- UTEC Owners please come in!! NEED YOUR ADVISE!
- Strange rattling sound on throttle =(
- car is down
- Walbro 255 Installation DIY
- Best Mechanic Schools
- Torque Wrench
- You may be the cause of trouble code P0507
- COBB AccessPORT
- Power Steering Fluid Question
- Oil Consumption Test???
- KN Recharger Kit
- Funny sound from engine
- What mileage did you change your spark plugs?
- dealership question
- Purged valve??
- 350z Koyo Radiator, How do i make it fit?
- braided hoses?
- supercharger engine mods
- Car wouldn't Start, finally did with White Smoke???
- CF engine cover
- Throttle body coolant bypass kit
- Help???
- just orderd this
- Pully set (noob?)
- PLEASE HELP!!! Can't bolt engine/tranny together! :(
- Turkish TT G35 420ps 0.5bar pictures
- Belt and AC problem...need help!!!
- Heat Shield
- Help me with my Buying List - PLEASE :) - going built and FI :)
- Oil Changes
- JWT S7 Revup camshafts and Top Secret 100mm throttle body...
- engine misfire code?
- Fuel Filter?
- Oil Pan Spacer Kit
- Why Use Synthetic Oils?
- Ssv Kinetix Manifold
- ati procharger w/ kurumaz bumper
- can any mechanic help me out on this
- Rich or Lean?
- Quick question fast answer needed
- turbocharging a tip?
- 2005 Dual Intake
- FAST INTENSIONS Exhaust Break In
- ATI crank pulley
- What do you pay for an oil change?
- wrong motor oil in engine
