- Strange 'flutter' noise from engine - seems like a little loss of power !
- ecu reset after plenum/mrev2 install?
- shifter barring
- Suggestions for Modifications?
- Crush Washer
- midpipe question
- My car overheated!
- f/i to n/a?
- how long does it take infiniti to put in a new engine.
- Dm2 Idler spacer install
- Sale on Castrol Syntec at Autozon
- Custom 3.5" (90mm) CAI in the works
- Serious Fuel Smell....
- asking price for 04 VQ/6speed engine/trans
- New stillen radiator now fans always on???
- Help! Serious ticking noise coming from engine!
- Misfire on cylinder 6!
- Anyone have complications with spray?
- Idle pulley delete w/ DM2 spacer
- APS TT on G35x
- Early 03 sedan auto reflash updates:
- Engine fan running continously?!
- V8 Swap
- ok so im new :)
- Where can i buy the Mt Fuji emblem that comes on the stock engine cover?
- My DIY coolant drain, flush and fill
- anyone have AAM Comp Angled Intake Plenum Spacer
- Very disappointed in my mods, Please Help out, maybe i got a problem or something,
- plenum question
- Grounding Wire Recomendations?
- a little help on plenums
- Want More Power !!!
- need help
- '04 G35 Sedan Engine Tick
- what intanke to put on my g35???
- Serious question about my engine PLEASE HELP
- Need An Expert On Interlock!
- Neo Oil
- Someone please tell me what goes here!
- Megan v2 Test Pipe Question
- Tuners or programming chips
- Cost of changing DRIVE BELT
- Is anyone running Nitrous on their G35's???
- Timing chain or valve noise?
- need help 04 g35 missfire
- Oil change advice?
- Anyone tried STP injection cleaner?
- Oil Recommendations?
- Car "dies" at low speeds, just after servicing!!
- 64000 miles worth it???
- Loudness on Test Pipes with OEM CatBack?
- New NA Build for my G35 Coupe!
- Just installed intake, ztube, testpipes, plenum spacer. Whats next without FI?
- Kinetix vs. Motordyne
- 06' 6MT Oil Consumption HELP!
- mrev2
- Decreased throttle response
- Nismo Thermostat
- Is my engine dying?
- who has done the rb26 swap here?
- Dirty Engine Oil
- nitrous install ?
- Water gushing noise when accelerating
- Cams & Headers Installed
- Motor Ticking on 05 rev up 6 mt sedan
- Excessive heat into cabin
- which get more power the Race pipes or the Hi flow Cats
- HELP! New interior, Non funtioning tach/speedo, shut off and now no start
- Rack and Pinion parts relate to Strut and Sway bar??
- What can I expect w/Motordyne MRev2 & Copper ISO 5/16 spacer
- Help me out guys .... VDC, service light, and slip on
- should I reset my ecu?
- Possible oil problem & engine knocking??
- Service Engine
- just got the test pipes on today
- gasket blown??
- Looking For A Performance Shop In NJ!!!
- After market work - Dealership
- Have squeaking noises at cold starts before and after belt changes..
- 05 G35 Coupe 6mt ECU Upgrade
- Engine stalls when idle....WTF?!?!?
- Help Differential ???'s
- Changing the Gear Ratio on Your Car
- NGK Laser Spark Plug
- What do I need to make my motor a Rev-up
- injen super SES legal?
- confused with ECU
- Plastic filler for engine cover?
- Best headers??
- Should I drain my tranny fluid?
- Hard Clunk and High RPM ?
- Recipe's for Power?
- Spark Plugs
- Review on Power Steering Filter
- upgrade choices
- surge performance chip?
- Oil Leak
- "You need to replace your engine"
- what oil do you use?
- What's this burning smell?
