PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. clutch vibration when its over 4000rmp..is dat normal?
  2. DC Headers and ACT/Nismo installed
  3. hey gord
  4. Newbie Asks stupid warranty question about modding
  5. Wideband A/F Gauge
  6. VDC, Brake, Slip light come on while driving!!!
  7. Blackstone Reports
  8. Crank Pulley Installers
  9. shaky/fluctuating idle after installing the Kinetix Plenum
  10. Vdc Noise
  11. How do you add a third power adapter to an '03
  12. Stillen Hi-flo intake - HELP!
  13. Anyone had any problems w/ Pulley sets?
  14. Error Codes P1167 & P1273
  15. Not your usual break in question
  16. Noise question...
  17. Colored Wire Loom
  18. Need something Chromed?
  19. Technosquare ECU owners: I have a ?
  20. Kinetix Hi-Flo cat issues
  21. NISSAN oil filter??
  22. crawford plenum, cats, Y-pipe, Z-tube and pop charger
  23. True Cold Air Intake
  24. Would this ECU do anything?
  25. Borla exhaust with headers
  26. Smaller alarm remote
  27. How-to install Ground Wire kit?
  28. G H-Techs / TEIN CS coilovers
  29. Rear Brakes Clicking Noise
  30. Sleeved/decked block problem.... going to do engine #4...
  31. Getting two engines, are they worth it?
  32. 2005 vehicles responding to mods?
  33. What is a spacer/plenum?
  34. Best Intake Upgrade For The G?
  35. Throttle Body & MAF Sensor Cleaning
  36. Need help getting 3M silicone lube plus, wet type
  37. Quick question about Y-pipe
  38. anyone want to sell me their stillen intake? =)
  39. STILLEN Hi-Flo intake pic's
  40. Crawford hi-flow cats, Crawford intake Plenum, UR pulley, Gruppe-s y pipe
  41. PMI - "Poor Man's Intercooler"
  42. Manifold Bypass Mod
  43. Burning Smell in AC Vent!
  44. Newbie Needs help with OEM Air box
  45. Is anyone using an oil reservior catch tank?
  46. NISMO? Engine cover
  47. Need a conservative estimate for a 2004.5 AT
  48. The ECU Resetters, Grounding Wire Believers were right!
  49. Need Help from those with Cast Crawford
  50. Modifications and the drag strip, my observations.
  51. wanted: gauge pod for a coupe
  52. Mobil1 extended performance 15,000 miles
  53. Can you help?
  54. Motordyne spacer vs Plenum units....
  55. 03/04 vs 05 HELP!
  56. CryO2 vs. Nitrous?
  57. Changing Shift Light Settings?
  58. JWT Cams
  59. Disappointing Mods
  60. Best z tube and filter.
  61. Nismo Ground Wires
  62. Plenum gasket: spacer/plenum install
  63. Help: Anyone know where the AC takes the inside temp?
  64. Help, Clunk Sound After Starting Engine
  65. VQ35de Power
  66. Air Intake Preferences?
  67. what is this thing....any help appreciated
  68. Cats - Need you opinions on them please.
  69. Need Idle Help
  70. Help!!!!!
  71. Oil residue in plenum, normal?
  72. Guages // DVD player installation
  73. Help, hydro planning
  74. How many liters TRANS oil should be put in gear box?
  75. G35x dyno results
  76. FYI - One guys opinion on mods he has done (Version 2)
  77. synthetic oil comparisons
  78. Need mud flaps
  79. Will the Z tube benifit my 05 298HP G
  80. sneaky pete
  81. California legal headers ??
  82. Xede Piggyback ECU module
  83. few questions regarding Cai install...
  84. JET HOT GROUP BUY AGAIN. linked here.
  85. 2005 6mt
  86. G35 Coupe Intrax springs VS Eibach Lowering Springs
  87. True Balance
  88. The G45...a G35 with a 4.5L v8? Anyone swap engines?
  89. Official Apology...
  90. O2 Sensor Wiring Diagram
  91. Do I have to drill a hole in the firewall?
  92. I insulated my Z-tube
  93. The going rate for HEADERS installation for G35s
  94. MUST SEE MODS!! - Coupe
  95. Struts and spring installation in 03 sedan
  96. Please help if you can!
  97. SES Light - Bizzarre
  98. Pi-Thon Hose Clamps?
  99. Unichip Installation
  100. Engine Noise
