- P2135 trouble code service engine soon
- Highly Strange and Unexpected Engine Issue
- How to replace an OEM ECU for my 03? HELP!
- What size spacers i need?
- SLR performance chip!
- This cant be good... Coolant/Antifreeze
- OBD-II Sensor Location
- CEL's
- rpm's help fast please
- grounding kit
- de-pinning MAF plug
- slight change of drive belt
- what mods i need to gain 50hp?
- SPEC Single Mass Steel Flywheel or LUK Dual Mass Flywheel?
- Independent Dyno Test: VQ35DE RevUp + Plenum Spacer
- Titanium Engine cover and Radiator spliter
- Angled Plenum or "level" Plenum
- need help ASAP (crankshaft pulley wobbling...)
- when to fuel up?
- OIL/TRANS cooler question
- now what?
- Car won't start, AT Check light flashing, fan motor comes on - what's wrong?
- triptronic issue and more
- Aluminum Floor Jack on Sale
- 6mt swap offer
- First GTM G37 SC
- Is this a Throttle Body Issue - Help Please !
- Electric fan
- Leaking valve cover write in campaign
- Complex Code Failure G35 2003 SEDAN
- headers hp?
- COBB Post MAF Hose for G and Z Available Now!
- wireing harness question
- AC only works on 60!?! WTF
- Using Revup engine in none revup Z?
- engine questions
- lightened pully set qustions
- Buying parts off a tuned '04 350z
- Iridium Spark Plug heat range?
- 2nd Oil Consumption Engine
- PLEASE PLEASE Help
- Engine swap..what has been done and what is possible?
- SES Light: P0138 Rear O2S, Bank 1 Maximum Voltage Monitoring
- Soooo if we have LSD (well I do), why do we have ABLS?!
- Why does the clutch/flywheel chatter? It's random..
- Codes: p0014 & p0078...help!!!
- stainless steel braided hoses for ARC catch can?
- Sold S14 240sx NOW - Newbie G35 Driver Help Eccs Fuse Keeps Blowing?
- my dual tips are clogged...
- Opinion: Oil change based on miles or date?
- When I engage the clutch (let my foot off the pedal), I hear a click from the dash?
- Nismo ground kit
- This is upsetting.....with only 37,000 miles...
- Black smoke from mufflers when punching it....
- I just MAY have solved the engine oil burning problem on G...
- Engine smell coming through the vent/heater when driving hard..
- Help...
- Engine Smoking
- Spark Plugs for 05 G35x
- Service Engine Soon: P1148 & P1168
- Cheap Puraltor PureOne filters!!
- Strange Problem
- Car Won't Start, Key Problem?
- clutch / flywheel questions....
- multiple random misfires..need help asap
- User servicable fuel filter on G35?
- idler pulley
- BLOWN ring...now what to do??
- Low idle vibration
- Rough idle after swap
- Autometer DPIC Gauge ? ? ANyone with experience . . .
- Engine Squeaky sound
- ABS Trouble Code C-1109
- Cams???
- RPM drops when starting engine cold
- vk45de In A Gsedan
- Naturally Aspirated... Can the QV35 ever be like a V-tech?
- Air Filter removal from Stillen on 05 Coupe
- Howling noise coming from front of the car
- Basic Modding Dictionary (noob)
- exhaust feed back
- stock looking for upgrades
- Time to change fluids!
- my drive back to NY
- ebay pulley set
- Oil Coolers
- Shipping exhaust
- Thermostat Replacement
- bad gas mileage
- Rack & Pinion still leaking after repair?
- rough idle at star up..
- Mishimoto Thermostat?
- Weekend from Hell
- Car wont come out of park.....HELP ASAP
- 5AT + transgo + gears+ grounding wires+ nitrous= win?
- AT CHECK LIGHT! help
- Rebuild VQ35 Rev Up?
- Timing Chain (I think) Rattle lasts for a good 5-6 Minutes Need Help!
- what is the diference. trasmission 2003 and the 2007
- Tach not sweeping smooth...buying a G35
