PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99
  1. Small port on the intake
  2. which s/c to go with??
  3. BMC World Champion Filters
  4. ecu and tcu reprogram
  5. Good Mod Shop Indiana
  6. Z-Tube & Pop or Injen or Nismo. Advice Appreciated
  7. finished custom gauge pod
  8. AutoX
  9. normal sound of popcharger/ztube?!?!
  10. PopCharger Cleaning?
  11. Help on dyno results
  12. Brake Light Mod Idea
  13. 5W-20 Motor Oil ok to use?
  14. Intake Dynos
  15. Popcharger or K&N Filter
  16. Parking Light's?
  17. dealer installed cai and exhaust
  18. Whistle sound from Injen normal..??
  19. WHAT BRAKES to get ???
  20. Maintenance-6MT Coupe
  21. S/C- Split-Second or Technosquare
  22. Did a compression check on the engine! Results!
  23. CHIP
  24. Torque Wrench Suggestions
  25. Side by side Eibach results *pics inside*
  26. weird noise from Engine
  27. D2S HID Bulb vs. D2R HID Bulb
  28. Prototyping...
  29. G35x - Stillen Exhaust update
  30. Opinions Wanted
  31. ? ABOUT ECU RESET AFTER TS ECU INSTALL
  32. intro to my project g35 / where can i post pics?
  33. Pop charger on injen CAI
  34. Oil Pan and/or Extension?
  35. HELP HELP!!!!! lights
  36. HELP!
  37. VIDEO - 0 mph until I ran out of road - F1
  38. Mustang VS. Dynojet (GOOD READ!)
  39. Help on MAF and OBD II.
  40. Non-Plat plugs? Anyone use some?
  41. Brembo's?
  42. Mods & insurance problems
  43. KP Technologies Remote Window Rollup Mod -PIC
  44. Where can I get Double Din dash to put new head un
  45. Lifespan
  46. CAI engine water damage
  47. w00T or WOT
  48. burnt smell after 3 hour drive
  49. synthetic oil
  50. RT cats collapsed
  51. Side Marker Blinking DIY Mistake
  52. How to remove the Accelerator Pedal for Aluminum??
  53. Dangerous JWT Pop-Charger
  54. First Mods??
  55. going to HK...what parts to pick up?
  56. technosquare or SAFC
  57. mods are a scam?
  58. HOw many have Technosqaure?
  59. Crawford V5 Impressions
  60. Dirty oil at 2200 Miles
  61. www.hidking.com
  62. Technosquare ???
  63. ECU location???
  64. WARNING! Do Not Buy this item for your G!
  65. Tein H.TECH Springs vs. EIBACH G35 ProKit
  66. silly questions.
  67. carbon fiber trunk
  68. Check out my new grounding kit wire
  69. A got to have item...
  70. Maintenance sticky?
  71. CF Engine Cover Rubbing Air Inlet Duct
  72. Obayashi on a coupe?
  73. +15HP ?
  74. pop charger install instructions!?
  75. Jerking Motion, Anyone?
  76. First Oil Analysis Result
  77. CF Hood Owners - hood pins?
  78. TS Flash - is this detectable by the dealer?
  79. ECU Upgrade???
  80. G35c Wald Body Kit
  81. intake for dummies...
  82. QUESTION ABOUT TS ECU RESET
  83. Mod friendly service departments in Chicago
  84. Unorthodox pulley install
  85. Anyone know a good R4 Splitsec Tuner in Dallas Tx.
  86. Polished Heads.
  87. install cost?
  88. Reading dipstick... how much oil to add?
  89. You gotta get, that, dirt off your shoulder
  90. Fumoto drain valve
  91. Does Infiniti mind?
  92. 350Z & G35 Day
  93. $1,200 to spend - on what?
  94. Dip Stick Guide
  95. Notebook scanner tool??
  96. Harm in a bad ECU reset?
  97. eibach or tein springs
  98. 350Z-g35 ecu swap completed!
  99. Fogs, clearance & corner bulbs upgraded
  100. stillen stage 2 dynos?
