- Wire Diagram for 2004 G35 Sedan
- Sparkplugs Questions
- UTEC vs. Reflash
- My car turned off while driving....
- Hard Starts...
- Wow, spark plug access is a pain!
- Kinetix plenum installed
- 1oz. Acetone + Tank of Gas = More HP, better milage, and less polution
- Apexi Neo
- Results of my oil consumption test.
- mid section help
- What do I have?
- $500 for Mods, what would you do?
- converting to E85 Ethanol
- How easy is it to get to 320whp NA?
- help with new mods
- Those with FI Intimidator.. which finish did you get?
- Cam Question
- Richie Front Strut Bar Installed
- HKS pricedrop?
- Engine Ticking Noise
- Dynod for a new baseline of the new longblock
- engine shut off @ 115mph
- power steering fluid for '05 sedan
- Tach needle acting up
- Vortec SC Or Porchanger???????????????
- need help
- Need help; potential leak?
- OMG, need to sell a SSV, go to ebay!
- Going back to stock...
- car is runing very lean, need help.
- why mix redline mt-90/mtl 70w80
- charged the battery and car wont start
- Maxima engine.
- So confused abut the MREV and spacer????
- black synthetic oil?
- Stock Fuel pump/ Nitrous questions
- Need new battery help
- Hks K-pro
- Exhaust Question!
- power steering fluid?
- Has anyone used a Z1 Built Engine Block?
- sedan stillen exhaust de assemble
- AAM Flash – dyno, pics & vid!
- just a quick question
- Cleaning Throttle Body: How? diy?
- 350z engine cover on g?
- FS: Fujitsubo exhaust + y-pipe
- pulley belts
- price for RB26 swap on G35
- Motor Mounts -NEED Hi Performance
- Amsoil vs Wix filters
- people use Mobil 1 syn oil..
- Ground Wire Kit
- Ecm
- g35 6spd
- How much hp will i gain?
- Question about a couple engine noises...
- The coolant control valve with iso thermal spacer
- aam vs. md spacer
- rods and pistons on ebay
- Which would you choose in the 08 ... turbo or NA
- HKS, w/ JWT popcharger and Z tube Sound Clip
- Blew the Power Steering this weekend
- Ecu part number
- service engine light
- Set up for car
- Where's a UTEC tuner in LA / OC, CA? Opinions on UTEC!
- VQ 35 motor for sale on ebay
- New Stroker Kits???
- 05' G35 blew coil pack. need help
- Amount of labor needed?
- full synthetic, not recommended?
- Who's Sharif
- Replacing Spark Plugs, One step colder or oem?
- G35 coupe + regular gas... knock sensor help !
- Why i cant get a MREV2
- Chip
- Spoke with service advisor RE: oil leaks, consumption
- Anyone have a 350Z AAM Modified ARC Catch Can on a G?
- GReddy V-manage (Variable Valve Timing Controler)
- Pop rivets
- New Hood Dampers...the good ones!
- Looking for a stock airbox for 03 sedan
- Unichip
- Do I need new belt?
- Car got dyno'd today...
- Unichip Cheap!!!!
- squealing belts wd40??????
- How many are NA and FI'd?
- Best spacer with Supercharger??
- non FI Performance
- chain dragging noise
- Did Infinity change motors mid 2006 - oil burning question?
- Bov?
- Any modification for better gas milage ?
- headers help
- What Samco Hose is this? (maybe G352NV can help)
- Purolator PureOne PL14610 Revised
- Does this happen to your G??
