- Valve cover spark plug tube seals
- Coupe won't run!
- Idle Trouble and DTC codes
- How to tell if you have CD009 transmission?
- Car having trouble starting.
- Warm starting issue/ AT check light?
- Clutch job done right?
- DIY Low Profile Ramps - great for changing oil on lowered g's
- Spark Plug Gaps
- G37 g35 MAF
- A note on leaking valve covers & cold start up noise
- Help w/ Engine missfire P0300
- Question on Osiris Tuner
- Weird overheating 2005 G35 AT Coupe
- Raising Idle
- Cam covers question
- New Infiniti Incentives and Rebates – Dealer Negotiation Tricks Email
- WTF: I need advice quickly
- Idling at 800 and CEL after DIY's
- Intake Valve Timing Control Solenoid
- Infiniti G35 2006 6MT Engine Noises Please Help
- What does this plug go to. It's unplugged
- I need help!!!! Engine Restorer
- HELP!!SES keep coming back after installing test pipes and non fouler fix
- Help! Seafoamed G35 Sedan and got 3 Codes!
- oil cooler install- thread sealant for aluminum fittings?
- Clutch getting harder to push in on my 03G
- Major Engine Problem - Need Help
- Quick question about a easy hp gain.
- Fuel gage calibration
- Car Stalls Again(once in a blue moon)
- Oil Filter Relocation???
- Clutch noise
- Rev-Up
- Only fill up on 17.2G when monitor shows "---" for remaining distance left...
- Possible Exhaust Leak?
- Knock sensor on VQ3.5
- engine swap out
- Do I need to change my oil after seafoam or lucas only in fuel? Also Seafoam VS Lucas
- Squeeling belt?
- Help please
- Baltimore Area - autoenginuity scanner
- Service Engine Soon light came on
- car noice and smell
- Deep rumbling 10-20 mph. Common?
- MD 5/16 spacer installed. Whistle noise.
- Do all VQ35DE's use the same ignition coils (G35, Altima, Maxima, etc?)
- 03 G35 Coupe valve tick [does it have hydraulic lifters or not?]
- Question, need help from the pros.
- car won't start.
- idler pulley bearing replacement
- Confusion with VB upgrade
- Replace air filter on G35X
- White Smoke from exhaust???
- Drivers side reservoir cover install help
- change the oil filter without changing the oil?
- VQ40 in 04g35x
- HELP! Doing a spark plug replacement and need advice
- Is there a correct answer to this or not?
- maf sensor
- First timer with a poll
- Reflect-a-cool. heat aluminized reflection foil
- Timing Too Advanced?
- What is the circumference of Stillen Z tube
- Engine squeaks on cold start ups
- Noise/Rattaling When Car Is Turned Off Please Help
- Larger Fuel Tank
- Help really bad gas mileage
- fuel injectors cleaner?
- 1 step colder plugs
- delayed shifting problem, help please
- oil cooler- mounting and checking oil level
- RPM problem???
- non-revup 6spd coupe dyno results: i/h/e + reflash
- new exhaust question
- Fuel type for '06 G35X?
- Quick Question people
- My car is leaking something, any idea what?
- Need tech help please
- Quick Question
- Check Engine Light and Boggy Acceleration
- White Smoke coming from exhaust
- G35 X and high oil consumption with Full Synthetic Oil
- opinions on Royal Purple Oil....
- AC Clutch Problem / Loose Belt
- Is this a Rev-Up block???
- Overheating and no heater
- How hard is it to switch out motors, mine blown
- Installing Mods, quotes on price to install?
- Old Gas Question
- Blaster Coil Question
- Ok...TSB on burning oil. What do I do about this?
- Feeler: SxExCx V2 Grounding Kit (STEALTH)
- E3 spark plugs for FI application?
- chugging/glugging sound from the engine when slowing down to a stop??
- Camshaft Position Sensor
- VDC+Slip+brakes grabbing at start. Did anybody get an answer?
- Y-Pipe / X-Pipe / H-Pipe / Dual-Pipe
- G35 Left running while fueling...car shuts off! HELP
- oil vs spark plug issue
