- MREV & Motordyne Plenum Spacers
- Feb JDM Option Mag - tuned 350z scanned
- Tri-Phase Performance Module
- Warranty Voided on stock car due to Aftermarket OIL FILTER!!!
- Vortech Install on Long Island
- MREV... Just stock 03-04 Lower plenum?
- Bullet downpipe and exhaust manifold
- What Next?
- advancing timing 2 degrees with NA stock cars
- Blitz R-VIT Multi Meter
- How cool is too cool?
- Z-Tube, pop charger, & 1/2" Plenum on 2004 G35: What Results will I get?
- Engine Service Light
- engine management for NA mods
- Stillen S/C will be here Thurs!!!!
- removing oil dipstick
- Need help PLENUM SPACER, who is the expert?
- Stock exhaust size on G35 Coupe?
- Expected Gains for these mods?
- MREV ordered
- Leased G's and MREV...
- What are the best mods out there man?
- Dyno Shop
- fixing her mechanical flaws...please give your 2 cents
- search results kinda sketchy, Im bored in the snow so heres a question....
- "closed loop"
- all around garrett turbo
- Shuts off after high rev acceleration -> neutralization
- 03 G35Coupe 300hp
- Running Rich?
- Installed Headers and Plenum Spacer
- recommendations for a decently priced inch-lb torque wrench?
- Injector cleaner in a bottle, are they usefull?
- Service Engine light after stereo install
- Who's been wrapped by the po with test pipes on?
- Strange Noise in 1st/2nd gear
- Headers
- Just hit 40k Miles
- engine air filter
- Mrev plus VS Crawford plenum + cats
- Stillen Engine Dampner DIY?
- Size of engine cover screws?
- All this pulley talk? Here is what they look like.
- Bad Metallic Noise!
- MD spacer owners, do your center bolts stay torqued?
- What Would You Do!
- To all who installed plenum spacers...
- Will Cabon Fiber Engine cover fit with Kinetix Plenum?
- Which MD plenum is best for 04' 6MT
- alphawerks 350z same as g35?
- Brand new Crawford Polished Plenum on Ebay
- Marchesanos engine cover!
- Stupid Question But F It
- Plenum Spacer...
- KINETIX ssv
- Question for the EXpurts
- What's this sound?
- What results would I get?
- Dealer ask me 1G for header install??
- Where is My ECU??
- Got my car back from Shop...OVERHEATING PROBLEM HELP!!
- UTEC on almost stock car?
- Dyno'd my bone stock 2006 6MT (plots inside)
- How hard is G35C oil change compare to Hondas?
- Open loop (WOT) fuel map
- Grounding Wire Placement
- PCV valve
- Wtb Stillen Stage 3 Pulley
- Does anyone have any Dyno Results from ECU Resets?
- Need advice...problem screw broke.
- Boost in MPG
- Mrev
- What happens if you start the G with the engine running?
- GReddy Catch Can
- Plenum Help
- MD Spacer or MD w/ISO
- Problems when storring in
- Service Engine Soon MREV Installed --- NEED YOUR HELP!
- Feeler: Brand New Nismo R-Tune Camshafts
- Idle problem.....Need some advice...
- Motordyne plenum Spacer Problems
- ATS carbon LSD @ Laguna Seca impression.
- JIC or Fuju Y-Pipe?
- Plenum vs. CAI
- PLENUM QUESTIOn
- Abs Turning On?
- ECM tuning - basic question
- Toronto Ppl!
- Dyno results from tuning with Technosquare and Motordyne!
- URGENT: MREV installed + 5hp / + 16 ft/lbs only? and Pinging
- Port and Polishing engine?
- Am I in trouble?
- Quick question???
- Auto-RX
- All this Mrev talk...but.
- Kinetix Plastic Plenum oil leak?
- Ground Kit
- UpRev Cipher: anybody try theirs yet?
- Crank Pulley, does yours do anything?
- No rasp and no SES light
