- Dealer told me synthetic oil not recommended
- underdrive pulley
- Stillen Srut, Clearance? Help?
- stillen s/c
- Fx35 fan noise/vibrations question
- air filter
- benefits from getting this AAM spec long block
- oil catch can
- 2006 FX 35 Seafoam
- well, oil consumption has claimed another..
- Pro-1 Engine Damper
- GroundingGear® on 6MT
- No Sprak Help!!!
- What kind of engine oil should I use?
- what mods to get first
- rev-up and non rev-up
- How do I bleed the cooling system?
- Spacer Question
- MPG: 87 vs. 91
- Spark Knock/Pinging
- Unplug battery on G
- Starting with these mods...
- Have you had
- Pulsar Plugs
- rear brakes / drive belts gone after 44km?
- Car starts, but shuts off, unless gas is applied
- HELP!! Throttle Not Working; Car is Fully Disabled
- water-methanol injection
- Stillen Radiator
- stupid ques. rev up & non rev up
- Hard Cold Starts :(
- REVUP or non REVUP that is the question
- How do I replace the battery
- Strange noise when A/C is on
- intake vortex?
- Unichip
- How can you permanently disable VDC?
- Stock Wideband
- help in DIY for Injen cold air intake
- Optional Rear Active Steering Package
- New Radiator option from Stillen?
- Gauge Cluster goes awry
- Nitrous Thread
- Which year would you start with???
- Factory lower Plenum question
- Quick question spark plugs
- Unorthodox racing pulleys
- Ordered built motor
- Need suggestions on next mod, please help
- buying injectors?
- oil to use
- Engine Cost
- Gauges that'll color match to OEM interior lighting (orange/red)
- car turning off?? PLEASE HELP!
- What can be causing this???
- boost sensitive regulator
- Starting problem.... need help.
- $2k Engine Mods
- Engine shutting down after Nav install?? Help!!
- What Does this Light Mean it showed up on my Dash
- replace coil pack?
- g coupe shuts down
- Engine too loud?
- Hose help...
- 2jz swap
- I need to aks the experts
- Transmission flush
- V8 Swap into a G35?
- tq rating on a g35 6M trans
- Stroker kit ~ need help
- Intake Plenum Spacer
- recommended fuel injectors?
- water
- built motor
- Anyone race a similar car with spacer vs no spacer?
- What is happening?!?!?
- 96 Dsm Gst?
- HELP! Where is the fuel damper and hose???
- WTF is this knocking noise?! HELP! (Yes, I searched)
- Fan Temp
- g35 sedan (base model) limited slip conversion?
- How loud is your electric cooling fan and how long does it stay on?
- what is happening?!
- Infiniti online parts catalogue
- oil
- 65k maintence and TB cleaning w/ Nissan part #s
- If I want to....
- Kragen Floor Jacks
- How to get rid of Check engine light?
- Motordyne 5/16 or Kinetix V+ Upper Plenum
- P0340 bank 1 question - camshaft position sensor
- Can someone Clarify for me?
- Car Humming at High Speeds
- 350z's aftermarket Radiator?
- HELP PLEASE!!!!!!!!!!!!! ASAP crawford v4 plenum... W/PICS
- any-body have any suggestions for performance spark-plugs& wire sets(not universal st
- Installing plenum spacer - torque wrench suggestions?
- Motordyne 5/16" Spacer
- Have a problem with my car..
