PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. 40k, changing fluids on a X-model
  2. Fuel tank problem
  3. Lower Gas Mileage Perhaps?
  4. 07 G35 ECU located at?
  5. Used wrong oil in my car, ahhh!
  6. Need HELP ASAP after HKS Exhaust Install!!
  7. Bad Engine/trans Mounts
  8. larger oil filter alternative
  9. Service engine soon light SES
  10. I searched.. but I need an explanation - OIL types
  11. oil consumption and octane ping.
  12. has anyone installed the sun automobile hyperground system?
  13. Problem - 2003 G35 Sedan - Please Help
  14. Problem - 2003 G35 - Please Help
  15. Chatter noise
  16. 2007 G35 drivers please read!
  17. Rev up Question...
  18. Car Won't Start
  19. Noob Question....
  20. Overheating 2006 Coupe???
  21. Dented Oil Pan
  22. oil consump. dipstick tied down?
  23. Y pipe questions
  24. '03 head on '05 block?
  25. best replacement radiator and electric fans?
  26. FI Intimidator with SC?
  27. Coolant smell but no LEAK
  28. Few questions i have about my G copue
  29. Coupe over heating...Yes I used the search tool.
  30. performance chip
  31. Error Lights
  32. Fuel Injector ???'s
  33. recommended radiator
  34. Ground Wire Help
  35. Turbo XS UTEC vs UpRev Osiris
  36. my car
  37. Intake ques
  38. G35 Coils
  39. DIY on engine damper from ebay
  40. WIGGLE/Vibration In Shifter
  41. Changing plugs, are these ok?
  42. Polished Plenum
  43. First DIY oil change done, couple of questions remain...
  44. Interesting: switched from Mobile 1 Syn to Valvoline Syn: oil consumption
  45. Loud screeching noise
  46. Are Drive Belts covered under warranty
  47. 3.7L VQ - whats the tech diff
  48. Engine noise from interior - bad fuel pulse dampener?
  49. Weird metal? sound from car
  50. oil consumption with normal compression???
  51. push-screws?
  52. Rev-Up The Difference...
  53. is it normal for the cooland level to vary slightly with ambient temps?
  54. How terrible am I? 70K First time AT/DIFF fluid change!
  55. engine power loss when sound system on High
  56. i need some new belts for my motor
  57. help finding chrome caps?
  58. Ooops What did I screw up now!!
  59. Help!!! Engine overheating!!!!
  60. Nissan/Infiniti techs: head work actually done?
  61. 2nd gear
  62. NGK iridium IX set- under $40
  63. Want to upgrade my Engine. Help pls.
  64. How do i know if i have a HI-REV engine or a NON-REV
  65. How much oil does everyone burn/consume?
  66. Some Advice
  67. is a Utec needed
  68. Badly In Need Of A 06 Rev Up Engine Harness
  69. any N/A mods that do give decent gains to our G?
  70. o2 sensor mix up?
  71. AC FAN rattled loud and is now off
  72. Stroker 101 please
  73. Oil in the engine bay???!!!!
  74. Plenum Spacer Warranty Issue?????
  75. I "FIXED" my oil consumption on the v2
  76. Oh boy! no start
  77. Bank 1, driver or passenger side
  78. Castrol Euro formula (German Castrol)
  79. Help With This Issue....
  80. My car shut off on me as I was driving!
  81. Help! 15 Mpg!! Whats Wrong!!???
  82. Topspeed Pro 1 Engine Torque Damper
  83. Oil drain plug washer question...
  84. Engine stalls on "warm start" any idea?
  85. stroker kits
  86. Motordyne spacer!!!
  87. Stillen airbox install questions
  88. Help - Engine Noise
  89. Need Help w/ 60k maintenance
  90. performance chip
  91. Ignition - HKS
  92. Starting Issue
  93. How to fix: P0340 code, VDC on, SES on, and SLIP on
  94. I want headers???
  95. Can someone tell me what exhaust this is???
  96. New Owner
  97. What should i expect??
  98. COBB ECU programmer
  99. G35TT with Ultimate n Greddy harness wont start
  100. Torco motor oil - UpRev recommends
