PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Service Engine Soon light - On
  2. 2005 G35 Stumble No Code
  3. 06 VQ35 Revup VTC cover leak
  4. ticking noise
  5. Decent Vortech alternatives
  6. 2006 AT Coupe Rear Main Seal
  7. 2005 G35 ECU wiring harness
  8. Engine making weird noise
  9. No Start 2008 G35X
  10. G35 ipdm or short or??
  11. Gas tank won’t fill all the way
  12. 04 g35 swapped with 03 350z
  13. G35 codes p2122 p2128 p2138
  14. Radiator Overflow Empty
  15. 07 G35 Fans shutting off after AC is turned on
  16. High idle, p1078 and p1084
  17. Ticking sound
  18. Transmission Not Engaging Gears Z1 CSC Elimination Kit
  19. Please help me find the original program for the engine
  20. OEM vs Aftermarket Chain Tensioner
  21. Weird slight overheating issues in 04 coupe
  22. Jim Wolf Twin Turbo Removal
  23. P2a00; do these o2 voltages look normal w/ respect to rpm WOT?
  24. Fuel Line Leak/issue Part #16454
  25. Overheating?
  26. High Compression
  27. Infiniti will start but makes pops soon as it turns over and intermittently pops
  28. Transmission Swap from 2006 Coupe G35 AT to a 2005 Coupe G35 AT?
  29. Please Help- 2007 Auto Coupe loss of power while driving, now cranks but won’t start
  30. ECU Questions!
  31. Extremely Hard To Turn Over
  32. Rev up Lifters
  33. 2008 Infiniti G35 Sedan
  34. Gear Ratios and Final Drive Confusion
  35. Low Voltage to Fuel Pump
  36. overheating again
  37. Engine bay rattle under load
  38. Fan continually running/ possible blown radiator
  39. My best way to bleed air from coolant system, no overheating.
  40. Car Cranking not starting, electronics don't turn off
  41. Engine looses acceleration while on spray in 3rd gear. (100 Wet Shot)
  42. What is this Noise?
  43. Changing Motor Mounts: Every stupid thing you need to know
  44. Hestitation while driving
  45. 03 g35 sedan overheating issue
  46. Transmission problems 08 g35 S
  47. Clutch meant for abuse
  48. Cracked rad support
  49. My Turbo G35 De
  50. 04 g coupe u1000
  51. Uprev Governor Removal
  52. 2007 g35 twin TB installed in a 2005 coupe
  53. Which diff does my car have?
  54. revup to non-revup - what it cost
  55. Engine swap compatibility???
  56. Question about 08 g35x stroker and mods
  57. Valve Cover rear hose routing
  58. No Spark...
  59. Camshaft sensor oil seals
  60. Limp mode after letting someone drive my G35
  61. O4 g35 6mt surging through whole rpm range
  62. 2JZ Swap 2003 G35X
  63. On the fence for HFC or HFC’s w/ resonators.
  64. Revup to non-revup - how it went
  65. Engine swap Crank but no start
  66. Timing Chain Replacement While Engine in Car DIY?
  67. ECU compatibility between G and Z
  68. 2008 G35 Sport Sedan Manual 6 speed. Died on road, now making noises from engine.
  69. 2006 Vq35de compatible to 2003 (de) wiring harness
  70. Please help I’m losing my mind
  71. Strange complete loss of power
  72. Engine management slip vdc lights on
  73. Swap rev up with non rev up
  74. Oil Pan Obliteration (Pls Help!!!)
  75. Swap wire harness from sedan to coupe
  76. Milky Okl water pump failure
  77. JDM Engine Swap Prep
  78. G35 Lost of power?
  79. whatsapp@ +27 684 211 804 buy masonic magic rings join illuminati in Detroit
  80. Multiple procedures for ecu reset
  81. Multiple Missfire and opposite short term trims
  82. Stalling but no ERROR CODE !
  83. resonated test pipes $150-300 that are actually in stock?
  84. engine smoking N over 1rpm studder
  85. VQ30DD & VQ35DE project
  86. G35 Rev-Up Engine Rattle, almost like a loose heat sheild..
  87. ticking sound from engine
  88. Need Help ASAP ABOUT MY G35
  89. P1283 p1273
  90. G35 intake manifold gaskets question
  91. Clutch pedal won't engage
  92. VQ35DE who can install PonCams
  93. HELP ! Overheating !
  94. 2005 G35 Auto - P0021 and P0011 is now P0335 Continuation
  95. Help !!!!!
  96. CEL Still on, what Now?
  97. Difficult starts - what am I missing here?
  98. Quick Question on interchangeable parts
  99. Camshift Position sensor ?
  100. Transmission help !
