PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. How much for internals and what do I need? HELP!
  2. Impul ECU
  3. Where to ground Valentine 1?
  4. Need help about oil change
  5. ECU vs. PLENUM... if you can only have one
  6. HELP! Strange Engine Noise
  7. ...G shuts off at 70MPH
  8. synthetic or regular
  9. Mod GOD
  10. installed wires, ztube, and pop charger.reset ecu?
  11. Question about coupe mid-pipe install on a sedan
  12. weight reduction?
  13. Intake Twister???
  14. DIY for Y-pipe
  15. Sport Z Magazine - SoCal Dyno Day Article
  16. Finally finished Header Install
  17. Power that also gets Speed
  18. Aluminum Dash Coating
  19. INSTALLING GAUGES
  20. HELP! Just sold car and can't smog with Injen CAI!
  21. UV city lights & Led markers
  22. Single most powerful mod for under $1,000.
  23. Which air flow to get?
  24. Headlight/Fog Light Fuse FOUND!
  25. Switch Location
  26. Squeaky Brakes at 2700 Miles?
  27. 10w-30 Oil OK in Sou Cal ?
  28. need OEM plenum
  29. Gordgee's Grounding Gear-Impressions
  30. how to diagnose oil consumption??
  31. Removal of console boot facia
  32. TEST PIPE SMELL?...
  33. WHERE TO START
  34. Grinding coming from right front
  35. My car likes the Crawford cats
  36. Thinking of switching my INJEN CAI to Z-TUBE
  37. OBD2 scanners
  38. something weird happened to my coupe..
  39. Windows-Up and Ground wiring
  40. LOUDEST air filter
  41. Stillen SC Warranty "available"
  42. AC gone bad?
  43. chip for G35?
  44. 1st Set of Pro-1 Headers installed!
  45. How much power will I have?
  46. Z - Tubes! Polished and others
  47. Aftermarket steering wheel problem
  48. TEIN Lowering Springs Questions
  49. Reason Why COUPE allows springs w/o shocks?
  50. Z-tube ?
  51. Advice Needed - spoiler
  52. Sway bars w/o the coilovers/springs/shocks...??
  53. Dome Lights don't work = BCM problem??
  54. Cam's anyone????
  55. Kinetix Plenum CRACKED After 5 Months
  56. Need quick help on manual....
  57. stillen stage 2
  58. Z Tube, K&N Filter
  59. mods
  60. Pop Chager and Z-tube vs CAI
  61. raising idle RPM
  62. good deal on injen cai?
  63. Listing of all FI engine failures
  64. SIGNAL LIGHT WORKSHOP - PICS
  65. Updated pics of my headlights
  66. Crawford Catz
  67. ECU for 2003.5 6MT Sedan
  68. Grounding wire okay touching plenum?
  69. Bad day ... IT happened... the engine blew...
  70. Key Mod LED
  71. Where 2 buy wires for ground kit? HELP
  72. Oil Analysis - first 2600 miles on the turbos...
  73. Nav Accept Byapass
  74. Program Key Fobs? OUCH!!
  75. Wheel Size
  76. How much have you spent modding?
  77. So many questions...
  78. aluminum pedals
  79. What wire should I splice into...
  80. Grille Modification Part One
  81. CAI Mantenance?
  82. water leak, engine noise
  83. PULLEY UPDATE miles/problems?
  84. Crank pully and set? any good? Need info/help plz
  85. Mods Installed
  86. Is this a good deal?
  87. DVD
  88. hp calculation ?
  89. Anyone's INJEN CAI rattle?
  90. installing technosquare ECU, ecu resetting necc?
  91. SoCal Dyno Day Results
  92. JIC Y-Pipe Finally Installed
  93. Technosquare update for 2004.5
  94. Will 255's fit in the rear with the 18" wheel, has anyone done this?
  95. small muffler??
  96. Dome light housing removal??
  97. Auto Lights Questions
  98. Engine Cover Screws are Broken HELP !
  99. HELP!! LOW TIRE PRESSURE GAUGE WONT GO OFF
  100. RacePipes+DC Headers=Damaged Headers?
