- Rev-up rebuild?
- Car Overheating Bad
- Unfortunate Events on Car Startup, Need help!
- Having trouble
- Vdc/off, SLIP, AND CHECK ENGINE LIGHTS ON
- Engine Ping/Pre-Detonation
- Rebuilding 75k mile VQ35DE Rev-up engine before problems?
- Aftermarket Lower Oil Pans for G35X?
- V35 vq25det + z33 swap help please
- (Stock) 2004 G35 Coupe lost power and exhaust note??
- Cooling fan troubles
- Rear Main Seal & Maintenance
- car won't start
- engine problems
- Upper oil pan
- 2006 G35 Coupe Engine Ticking?
- 04 g35 coupe engine problem
- help a brotha out!!!!!
- Car stalling when turning
- 350z valve cover alignment tool
- 2005 Infiniti G35 Battery Fuse
- Swap question.
- HELP! Overheating - Coolant leak
- Rear diff or wheel bearings?
- 05 G35 A/T Engine Swap - Won't Start
- another p0011....
- Looking for a second opinion
- Getting the right ECU
- Replacing belts soon. Idler pulley delete?
- How do I fix code 0340 camshaft position sensor a bank 1or sensor n 462
- But whyyy???
- Intermittent No Start
- Misfire/ hesitation while accelerating
- Stalling/hesitation when starting from a dead stop
- Crank Strong. No Start. Doesn't Run. No Injector Pulse.
- Modified my 05 G35x - noticiable performance increase
- '07 Camshaft Position Sensor Location
- Refilling
- Loud whine from engine
- G35 Overheating Issue, Help
- 2008 G35 stalling out!
- 2004 g35 auto tranny, in a 2005 g35? Will it work
- Is it worth it?
- Overheating Mystery Revisited
- 05 g35 no start
- Engine Replaced and Stalls Upon Start Up
- 2003 g35 sedan never changed trans fluid
- 03-07 g/z rack and pinon threading
- 2004 G35 valve cover spark plug tube seals
- TDC Timing chain help!
- Checking AT transmission fluid
- Changing my auto transmission fluid question
- Motordyne mrev2 lower intake plenium????
- Heater hose replacement
- G35 Coupe LS3 swap Accelerator pedal
- Stumped removing fan pulley bracket
- Increasing HP at Wheels
- Blown Head Gasket?
- Haven't Driven My G In A Few Months Now Some Issues
- G35 2005 6MT Knocking noise
- Water pump stuck
- Engine rattles when accelerating
- Cleaning Fuel Sensor made problem worsen
- Loud noise when turning
- Pathfinder Cooling mod
- Oil smells like gas
- 03 g35 coupe so lost with where the water is coming from in the oil.
- cam sensors
- Can the Rev up Block warp
- Mulitple misfire...
- Fuel Pressure to Infiniti i35
- Proactively replace camshaft and crankshaft sensors?
- ECM Failure
- 05 AT vq35DE swap for VQ35HR ?
- Camshaft and EVT position sensors
- engine making a loud knocking at low RPM
- Boosted G35-Torque Converter issue or Trans
- The new to me headache! 2005 g35
- 5AT engine convert to 6MT chassis.
- Need an up to date Twin Turbo info (2017)
- Needing some advice on engine replacement
- has anybody installed a twin turbo on your g
- I need opinions on my ATF color
- Vq35de vs. jdm vq35de questions
- Plenum Spacer Install
- Head gaskets blown --which to buy
- Knocking noise in park and neutral only
- Help - Car making loud noise
- G35x gas mileage
- 04 g35 coupe auto to manual?
- G35 Misfire No Code HELP!
- 2005 G35x sedan in 2004 G35 Coupe
- Overheating?
- 2004 6MT VLSD into my 2004 5AT open-diff
- Oil Cooler Gasket Leak?
- 2003 coupe vs sedan engine differences
- P0335 2007 INFINITI G35 - Crankshaft Position Sensor Circuit Malfunction
- Major 500+ hp engine build on G35 Coupe?
- Fan pulley bracket 03 issue
- 2005 G35 Coupe MT Fluid Questions (Coolant & Oil Burning)
