- Cam shaft sensor problems
- Need quick help about engine install.
- Watch Out: Infiniti Spark Plug Replacement at Dealerships
- AEM Wideband Failsafe gauge?
- horrible noise please helppp
- Oil Consumption..Synthetic Oil
- Weird Oil Consumption
- Horrible gas mileage after ECU reset
- Need help on starting to mod
- 04 G35 overheating
- clutch getting "stuck"
- adding a flat fan to the ac condensor
- Supercharger build? Injectors, Fuel Return ARP L19, retune?
- Engine ticking noise...
- Need New Clutch
- Tanabe Exhaust causing Heavy Vibration!?
- Overheating... Don't understand why...?
- What else to do when while my car is on the lift?
- 2004 g35 sedan overheating
- Car wash + CAI.. Safe?
- Injen filter help
- Clear Self-Learning ? P1273
- need help for a full exhaust set-up?
- Noise Shifting
- Replace rev up engine with non rev?
- HELP. Headers for powerlab gt35r turbo kit
- Motor wont hand crank
- please help. Fuel return line size and length?
- Idler pulley and AC pulley question
- Charge Issue(E Brake and Charge Lights on)
- New driveshaft installation????
- Squeaky noise when shifting.
- How loud is a vortech for daily driving?
- shaking/jumping when idling
- Shifting issues after new clutch & pressure plate
- Power Steering Leak
- Please help......
- [VIDEO]--Engine Kock
- 2003 g35 coupe flex pipe size?
- Purolator Synthetic Oil Filter
- 2008 G35 AWD VQ35HR Engine Rebuild HELP!!!
- knocking noise coming from compressor area
- Engine clicking noise - Possible lifter issue
- KOYO V-core radiator & Vortech plumbing?
- Knocking
- low idle, engine wont turn over w/o revving
- What is this copper tube?
- 2005 g35 No spark help!!!!
- What year engine will fit my 04 g35 coupe?
- 2003 G35 Sedan: After Market Starter Advice/Tip
- Diy motor mounts
- DIY Power Steering High Pressure Hose
- Mass air flow faults
- Engine Swap Compatibility Question
- help, stuck on side of the road
- Valve cover question and a couple more
- My Vortech Radius Rod
- Cat Bracket
- Circuit Sports Direct Ignition Bolt-On Adds 10+ RWHP??
- Oil on my air filter and other problems.
- Radiator Leaking
- FX35 shuts off after startup (post cleaning TB)
- Plenum Spacer: Concept Z vs. Motordyne
- need some input on sketchy shop regarding motor replacement
- Transmision Question
- Radiator fan 3 way fuse resistance??
- 04 g35 coupe ecm communication
- HorsePower recommendations for 2004 G35 AT?
- Anyone ever get this whining sound?
- Two different versions of radiator for 2003 G35 Sedan?
- Head Gasket Replacement?
- One plug had oil, consuming alot of oil..
- Aramid gasket vs. OEM manifold gasket help
- Issues After Spark Plug Change
- Coolant air bleeder screw
- Belt tensioner pulley model numbers
- Throttle lag , can anyone give me an answer :(
- Rev-up motor question
- 05 rev up
- E brake light and TC light on ....?
- Fan clutch
- P0335
- gas tank probs
- NEED HELP! Oil Pan Gasket Leaking?
- Clutch Issues
- Drive belts
- Engine stalling
- Engine noise, heard in cabin.
- Release bearing question
- what type of oil & sparkplugs shoukd i use?
- Anyone Completed a 9000 RPM or high rev build?
- What needs to be done to my G35X
- no heat at idle,fan running,engine temp fluctuating,antifreeze burning smell
- Engine Swaps
- ls swap and auto
- Need advice on gas/oil additives on 100k+ G
- What am I hearing?
- i really need help!!!!! g35 infiniti
- Elusive misfire issue.
- Just won't quite....
