- Engine change in driveway
- How to change the thermostat on a 2003 G35 coupe
- Bank 1 variable timing issue, P0011
- Engine temp!
- '06 Sedan won't idle
- SxExCx: Now offering TransGo install...AMAZING deal!
- The FIRST aftermarket VQ transmission pan
- 2004.5 Wideband o2 Sensor and P1283 code.
- Installing stillen oil pan with gasket and not RTV
- wet weather/rain stall - hesitation - P0102 P0506
- Pulleys and best kit?
- Getting tired of the one thing after another!!!! Now a cracked greddy manifold !!!!
- Camshaft position sensor connector
- Valve Lifter issues (cam followers)
- vq35DE and vq35HR in depth comparison
- Valve Cover Gaskets - Ad Nauseum
- New Megan V2 tp's $100 go for it?
- Sound coming from Car
- Help -auto to manual- not starting
- Haltech Dual or Single 02 Sensors
- Hoping for feedback for any boosted who swapped 3.5 rear end to 3.3
- are most HKS replica's the same?
- Knock Sensor HELP
- Help identify this harness!!
- A little advise please
- Damaged hose, maybe radiator or AC, should i drive or tow?
- My vq35de blew. Can i swap it with the vq35hr motor?
- starting issues
- Is it a good idea to sleeve your vqde heard a lot of bad stories
- Power steering pump cleaning
- Plenum + clean throttle = troubles
- change radiator fluid?
- Upgrading fuel pump?
- TT Repair Shop in Philly Area
- Oil consumption mystery
- 03 G35 coupe white smoke passenger side engine
- Vegas Heat = Need options for better cooling !!
- Engine Seized...Infiniti/warranty???
- No code, exhaust smells lean
- Oil consumption tsb with mods?
- Supertine/AC Belt Squeal
- P0011 cel/mil?
- ticking from engine?
- Engine Stuttering
- Stillen engine damper
- Radiator issue
- ECU Reset, IAVL, APP Relearn, & Throttle Valve Closed Relearn Procedures!!!
- Intermittant tries to start then stalls
- VQ35/37 swap into R34 GTR, and keeping AWD - need info!
- Plz Help. G is SMOKING from Exhaust
- Valve Issues
- Garrett turbos to replace APS turbos
- problems with g please help out
- Is a HKS G35 43001-AN003 Twin Power Ignition DLI II worth it?
- car hesitates under full throttle but not when rolled on ?
- Experiencing Power-steering Issue with my G35
- Type of OIL
- Coupe Mid Pipe with rattle
- Mileage too high for FI?
- Will a 2006 350z motor fit a 2003 infiniti g35 coupe
- BP Tubro with Motordyne TDX2 ShockWave??
- 03 G35 coupe 90k miles oil leak?
- Clutch system will not bleed. Need help.
- car hesitates under full throttle help plz
- Typical engine swap cost?
- Lower Plenum
- HKS Replica Exhaust
- Hose coupler for throttle body
- Overheating mystery, need some help
- Are 350Z and G35 Parts the same???
- exhaust questions
- Remanufactured engine installed low oil presure need help :(
- Whistle/Whine Noise after Iso-Thermal Plenum Install
- motor mounts/ dea or oem ? i need to buy 07 coupe
- What is intake valve timing solenoid
- Loud vibration noise coming from crank pulley area. Video inside!
- Engine Dress up parts
- can someone identify this hose?
- Screeching noise at start up. VIDEO!
- HR motor swapped into 1st gen G on My350
- problem with car
- G35 Car Rattles When Accelerating In Low Rpm
- rough idle after oil catch can install
- Downstream o2 sensors
- New Clutch?
- 350z Mid Pipe vs G35 Coupe Mid Pipe
- 03 g35 6mt grinding sound when accelarating in high gears
- Megan Racing Header. Possible Fraud. HELP
- What does that mean
- 69 follar chip legit?
- mods to add before tune ??
- Possible clutch needing replacement
- help. limp mode. p1065 & p2135
- HELP!!!!! Coil Pack Mounting bolt snapped off
- Are 02 sensors interchangeable?
- Potential Stillen S/C Upgrade
- G35 Supercharged Block Rebuild Help
- light engine sputter at idle
