PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Negative fuel trim? (-20)?
  2. My 04 g35 coupe is making raddling noises!
  3. 03 G35 Coupe
  4. Getting a P0420 code?
  5. spun rod bearing - looking to rebuild motor on 2007 6MT revup
  6. Can a bad coil pack lead to flooded cylinders?
  7. Jwt twin turbo help.
  8. Easiest way to unplug Camshaft Sensors
  9. Need recommendations for a ring gear stopper
  10. P0171
  11. 2005 G35 crank no start
  12. 2004 G35 replaced IPDM old issues fixed. New problem arrives.
  13. Leaking valve cover or valve cover gasket?
  14. Crankshaft position sensor
  15. G35 2004 engins stutter
  16. *HELP* G overheated,now won't run properly !
  17. Towed G35x AWD in Park
  18. check engine light after storage
  19. Help me ID these pipes!
  20. Help! Slave not engaging clutch fork after replacing
  21. Engine Whine
  22. Engine swap 04 Sedan 5AT
  23. Are the PCM and ECU the same thing?
  24. New to me 2004 Coupe MT
  25. Accessory Noise - Continues After Engine Shut-Off
  26. Has Anyone ever had this issue?
  27. Maximizing Normal Aspiration
  28. Engine swap issue.
  29. Question about NISMO S-Tune GT S2 Vq35de Motor swap
  30. Please help me fix my G35!
  31. Another question about the cooling system
  32. Lightweight Flywheel Question
  33. How long does it take to bleed cooling system?
  34. RB25 SWAP G35 COUPE (Will the clusters work?)
  35. Anyone using Z1 Motorsports Urethane Motor Mounts
  36. TCU problem on motor/transmission/harness swap
  37. G35x Auto Shifting Issue. Please help!
  38. 05 g35 coupe 6mt bucking at 4,000 rpm
  39. Jerking(Misfire) and 5th and 6th gear only?!
  40. Are all vq35 blocks the same?
  41. power steering pressure line hose replacement
  42. Which cold air intake filter to go with?
  43. Car not starting, please any help is needed
  44. 03 g35 coupe - flange exhaust leak
  45. 2004 g35 coupe misfire and now it wont start
  46. Infiniti G35 ticking when revving/accelerating
  47. RPM/decel dependent vibrations and drivetrain slack
  48. 04 G35 Crank/No start (dead horse thread i know)
  49. Changing Clutch Question
  50. Hose broken
  51. 2006 Infiniti M35 V6 3.5L Cam/CrankShaft
  52. Crankshaft position sensor
  53. Crashed G35
  54. Only half a qt came out
  55. Rattling Noise & AT Check light
  56. Hey bros, Is it common that g35 coupe make rattling noise ?
  57. Starter
  58. G35 runs without crankshaft sensor
  59. Possibly messed up trans pump?
  60. 2004 G35 Coupe running rich and no Codes
  61. Having issues
  62. cannot get rid of SES code..
  63. Is Engine compuer the problem???
  64. non revup swap to 06 revup car
  65. I got a clicking sound
  66. transmission Bleeder valve idea
  67. Does the g35 2006 6mt have a open diff or LSD ?
  68. Name of engine part! Please help
  69. LSD 1WAY from Nissan 180sx for G35 Coupe
  70. G35 slip vdc and cel all on
  71. G35 starts but shut off!
  72. Coils and Plugs
  73. P0300, P1446 and the factory recall...
  74. CEL flashes during deceleration
  75. value cover o ring gasket
  76. Help finding info of this intake
  77. Engine swap
  78. Help me understand
  79. P0300 and Possible Bad Cat Converter?
  80. Can I use these as replacement injectors
  81. Cylinder 3 Misfire 04 G35
  82. Nismo Diff help
  83. Removing ac line closest to firewall
  84. camsensor replcament
  85. Car has problems starting p0335
  86. Installing 440cc injectors on stock tune, what is the effect?
  87. Fuel Cutting under acceleration, Limp Mode, please help
  88. Engine shutting off
  89. Strange throttle issue
  90. Just Fixed My RAS
  91. Nissan Camshaft sensor ? P0340
  92. Cam position sensor code question
  93. ecu reset
  94. When to change oil?
  95. Valve cover gaskets/ more?
  96. Throttle body re-learn
  97. Radiator Problem & Suggestions?
  98. I think my starter took a dump
  99. 5AT with External Tranny Cooler
  100. Transmission leak?
