PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Why Fram Oil Filters Suck
  2. 2004 6mt shot trans 79K miles
  3. P2A00 and P2A003 Code Please help
  4. My g35 05 sedan noise
  5. HELP! Car doesn't want to start randomly
  6. DIY AC compressor tensioner pulley
  7. VQ35 Engine VIN Location?
  8. Engine Loses power - Test Drive Gone Bad
  9. 05 twin intake
  10. Radiator Rubber Mounts
  11. RPM needle bouncing upon start. Help
  12. Do we have the same radiator cap as 350Z?
  13. Drive Belt Replacement
  14. Several issues with my g
  15. Code from ECU PO507
  16. 350z mid pipe help question???
  17. x pipe test pipe help!!!!
  18. o2 sensor brand recomendation
  19. DIY valve cover replacement. Again
  20. engine noise ? light high pitched rattling from serpentine belt system ????
  21. Gauges suggestions
  22. Leaking coolant, water pump, timing chain tensioner.
  23. Cold Starts= idles at low rpm?
  24. Bosch O2 Sensor and P1273 Code
  25. Started out replacing clutch...Suggestions please...
  26. Help with a small rattle from the engine.
  27. Video of car burning oil.
  28. Right Code, Wrong Description?
  29. Help. P0037 error code
  30. p0132 & p0152 codes, rough idle when cold
  31. UTEC MAP vs MAF
  32. is there possible to installation
  33. best place to buy oil & oil filter
  34. Urethane transmission mount on automatic?
  35. 8 rib surp belt upgrade
  36. the_coupe's NA engine build thread
  37. bc valve springs
  38. 103 K miles should i get my transmission fluid changed???
  39. Car will not rev up!!!!!
  40. Do I need this hooked up?
  41. DS Mode shifts Down but not UP Help
  42. consuming oil
  43. ??????? about front wheel bearings
  44. to build or not to build.....
  45. Car problems!
  46. Thottle Body Cleaning
  47. turbonetics tune? what to do!
  48. Burning Smell & Belts Aren't Tightening
  49. Code P0011
  50. Keep blowing the fuse in the IPDM box that goes to the ECM Relay. HELP!!
  51. overheating
  52. limp mode on my car? URGENT HELP!!
  53. Aftermarket Aluminum Radiator...Worth it?
  54. D.I.Y. plug change
  55. Oil Leak Valve Cover Help
  56. new spark plug after 20 minutes driving- 1 clean 1 black
  57. Carwash and now my SERVICE ENGINE SOON light is on...
  58. Are the engines in the G's just loud engines to begin with?
  59. 6 Cyl Direct Port nitrous
  60. Looking to cam the engine. Any suggestions??
  61. Engine HORROR story...
  62. "Click, Click, Click, Click" from engine bay? Belts???
  63. "AT CHECK" light went on and no power when accelarating!
  64. plenum polished?
  65. Installing headers..
  66. testpipes, now Y pipe?
  67. Complete coolant bypass without coolant bypass caps
  68. Coolant Problems
  69. Car is running like crap... P1273/P1283 maybe?
  70. How to retrieve SES / CEL code on 2011 Infiniti ?
  71. I REALLY need a lot of opinions and pov's on this.
  72. Motor swap or F.I.
  73. OC block replacement but then storing for winter.. what to do?
  74. Engine noise on startup --05 g35X
  75. HELP!! Need heavy duty AC pulley bracket
  76. performance bolt on for g35x
  77. Blue smoke? Time to rebuild my VQ
  78. Please help! power steering question
  79. time to build a motor
  80. Turbonetics ST install!!
  81. Cold start engine ticking sound *With Video!*
  82. Resetting ECU after installing Spacer, did I do it right?
  83. Turbonetics kit + oil pan spacer
  84. Oil cooler sandwich plate connector bolt missing. Where can I find one?
  85. 2004 g35 coupe coolant change tutorial?
  86. Need Help!!!
  87. Need Help!!!
  88. Choppy Idle
  89. If I have airflow mods do I need fuel mods?
  90. Does turning one screw adjust the resting idle?
  91. engine help
  92. No spark. Need help!
  93. D.I.Y Power Steering Reservior
  94. F ME Help!!!!!
  95. O-ring = Blown motor
  96. 2004 vs 2007+ engine
  97. Thermostat Change
  98. Castrol Import Multi vehicle
  99. Thermostat Housing Bolt Hole Stripped
  100. engine popping noise!! please help!
