- Car Doesn't Want to Start
- injectors
- Oil problem
- $390 for ztube/popcharger, and UP Crank Pulley good price??
- New G35 coupe Xo2 Exhaust clip sound!!!
- valve spring compressor
- Honda Question
- Project Help, All Motor 500+hp
- belt help!
- purolator filter review
- Spacer Help
- Flashing Check Engine
- Car starts then dies
- Coolant on belts
- key fob
- turbo or supercharger
- Happy Day. Pix.
- Feedback and Questions on test pipes
- Ramps
- HELP> I cant open my hood..the latch is not disengaging
- mrev spacer
- wuts the difference
- turbo kit on ebay
- Stupid question re Motor oil
- Cold Air Intake and Other Mods
- Supercharged or TT 5at sedan?
- Baseline Dyno '04 G35 Coupe 6MT
- Has anyone used Extrude Hone before?
- pinging???
- What kind of real-world gains...
- NEED HELP, On Oil! Quick Question! 5W30 or 10W30 and synthetics???
- Nismo Power Steering Cooler--pix.
- Downpipes
- Hp Increase?
- new engine ?
- helppp....reverse will not work
- 5AT- APS adaptor
- Pulleys owners: how's the NVH?
- Pop Charger Z tube
- EMANAGE, UTEC, ECU flash?
- new to forum: Old G owner.. Question Rattle\Not clicking. From rear end Not interior
- really....
- ECU code 21? Is that what these lights mean?
- Blue smoke on startup...
- for NY 5w30 or 10w30
- check engine light after plenum install
- Looking for a shop to install gears....
- no torque?
- 30,000 mile service
- which would you choose
- How many quarts of oil?
- Another UOA, Pennzoil Synth vs. others
- Oil Film Strength - What is it and Why is it Important?
- Engine Service Soon light is ON
- ECU reset...did it work?
- I got a question:
- need help
- MD 5/16 Spacer question.
- Need Help! Second New Tranny, need advice for flywheel and clutch
- mrev2 with 5/16 plenum on 03 coupe?
- underdrive crank pulley?!?!
- New cams vs. advancing stock ones
- Twin Turbo in a 5AT and a 6MT
- 15K service questions v. leased car
- air filter is very very dirty... is this normal?
- Engine goes below idle rpm when disengaging clutch in low gear
- Oil Smells Like Gas
- Specs on internal engine parts
- Fuel Economy Tips
- All you need to know about oil is here:
- FTC Says High Octane Fuels Not Needed?
- Synthetic Oil Reduces Engine Temps? How?
- The Society of Automotive Engineers Recommends Synthetic Oils?
- Oil Viscosity - Is Thicker Better?
- engine bogging down after spacer and pop charger install??
- Bogus, "Oil Test" - Don't Be Fooled
- Need Help ASAP!! Fuel Pump
- Oil dipstick broke!
- What kind of Oil do you use?
- Project Car Stage 2 - MREV2 & 5/16 inch spacer
- oil levels/oil change with filter 5 qts
- Tip-tronic question
- Throttle Chamber Assembly
- Help!!
- Engine timing different in 4WAS models
- Carbon Fib engine cover
- Is a 400-500 hp all motor G35 possible?
- Brian Crower @ Intense Motorsports
- Interior Air Filter (In-Cabin Filter)
- dripping motor oil
- Kinetix spacer or skunk2??
- Any performance parts for the 2007 G35 ?
- What exhaust for APS single turbo?
- Plenum spacer opinions please!
- Installed UR Pulley yesterday
- ** Quick Video of my 06' 6MT with MREV, HKS Exhaust, etc. **
- Oil change issues
- How fragile are these engines? (Damage by theft question)
- Torque and power?
- Greddy Emanage Ultimate Jumpers Help!!
