View Full Version : G35 Sedan V35 2003-06
- 2006 Sedan 6MT Resurrection
- Loud Engine noise 2003 G35
- Stuck front seat
- 05 sedan crank no start
- WALBRO 485 Fuel Pump Uprgrade 06 G 35 Sedan
- Help with bluetooth aux yatour in g35
- 2004 G35 Coupe - DTC Code - U1000
- Anyone know if you can do an ac compressor bypass?
- seriously ? wire harness under battery always wet
- Swap
- Valve cover gaskets leaking or something else?
- Installing bluetooth/aux
- Which car battery? 26R or group 35
- SOS Cv Axle Disaster
- G35X TRQ Suspension Kit
- No Start Fans Running No check engine light security light soild red
- Oil burning after sealing head gasket
- Ipdm ignition relay color wire and what plug
- Transmission problem
- ATF For the G35X
- The G35x lives on, but for another owner soon.
- Key won’t turn
- Overheating dilemma, looking for a G35 expert mechanic in the New England area.
- 2003 to 2005 swapping parts
- 2006 G35 Sedan - dash by clock flickering?
- Gas pedal is not working
- Blend Door problem.
- blower motor will not engage
- G37 seats in G35?
- Reprogramming on cheap G35?
- No sound no crank
- Should I buy?
- Swapped 03/04 reverse lights onto my 05, now reverse lights don’t work
- 2006 G35X Powers On But No Crank - Shifter Interlock Problem
- Tiptronic only works when it’s cold.
- transmission swap
- Air bubbles
- Need ECU unlocked and wiped
- Checking engine oil levels
- Bad IPDM?
- Direct Swap for Early 2003 5at sedan
- Harness question.
- Crank No Start, No Fuel, No RPMs
- Power Steering Leak
- Instrument Cluster Options?
- Fuel Pressure Drop Extended cranking (Fixed)
- Keyfob programming help
- 2004 G35 Sedan Radio Volume Has One Setting
- Issues: JDM engine & tranny swap on 2003, G35, Sedan, AT
- g35x 2006 BCM code C1729
- Torque pro help
- Upgrading to Brembo Brakes
- G35x timing cover
- Over heating at idle
- CEL is off but I have error codes that won't clear.
- 04-05 g35 trunk interchangeable??
- 03 Sedan Front Sway Bar Link Pics
- G35 2004 Continuously Dropping Into Limp Mode
- Front left ABS Wheel sensor fitment issue
- G35x Motor Swap and Now car wont hold its self at idle.
- What Size Battery to Use??
- Help - AT Check light, U1000 + U1001 + P1574 codes from hard driving?
- Climate control stuck on defroster
- Need Help Very Confused
- Slip and VDC after fun switch
- Backup Camera installation questions
- P1757 Transmission error
- Part numbers for fender shields
- 2006 G35 6MT has a 'ding' when starting in 1st?
- Need help - G35x drivers seat won’t move
- Intermittent Start
- Custom cold air box for pop charger
- Mercedes Blue Coolant in an '04 G35?
- Swapping a JDM VQ35DE into 50-state manual G35.
- Steering U joint
- 03..auto on the west coast if anyone has questions
- Throttle body suggestions
- Stabilizer Bar Bushings
- 2003 P1716 Transmission Code
- ENERGY Bushings
- Weird Whining Noise Reving Engine to 2500+ RPM
- No wire on pin 101? Left foot braking fuel cut
- Weird loss of power
- Overheating issues on my '06 Sedan
- Car won’t start but cranks?
- A/C Drive Belt Horrible Noise
- High Coolant Temp But NOT Overheating
- 2005 g35x front drive shaft?
- 5AT Manual Mode... Obvious dead horse topic
- Oil filter housing replacement
- 05 g35x Ecu and IPDM trouble solved
- Vibration in gas pedal, and steering wheel under hard acceleration / above 50mph
- G35x high idle Oil smells of gas
- Help finding G35 Sedan Trunk Lid Finisher Plate Assembly
- Battery won’t keep charge
- 2004 G35 Lighting Experts
- Brake resivour leaking what would cause this to happen
- G35 exhaust to G35x
- Extra connector by tcm
- THE HUNT for 2005 g35x sedan Fuel Pump Assembly
