PDA
View Full Version : G35 Sedan V35 2003-06
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
  1. Woot! Joined the group!
  2. Trying to decide: '06 or '04 -
  3. foam block sitting on undercarriage cover?
  4. Reply ASAP! Difference between 04 & 06 G35X?
  5. What bumper is this?
  6. sedan mudguards
  7. anyone running 10w30 now/was
  8. Radio and AC controls Inop...help!
  9. picking up an '05 6MT this weekend
  10. 03-04 sedsn
  11. Hood grille
  12. G35X AWD / Snow Question
  13. Black Grille for 05' G35 Sedan
  14. HELP!! g35 wont start
  15. Noise around 2000 rpm what is it? Help
  16. Question about a Grille..
  17. G35 sedan with G37s RIMS!!!!!!!!!!!!
  18. A Cup-holder Solution for 6MT Sedans
  19. 19x9.5" rear fitment?
  20. 03 sedan front passanger side window motor
  21. Coolant // Overheating // Information
  22. bout to hit 60k, should i do coolant?
  23. AT Check Engine Light
  24. BC Coil Owners - Your Dampening Settings
  25. Can someone take a picture of a their stock trunk for me?
  26. Car cuts off when idle
  27. Hit a tire but I got a ?
  28. New G driver
  29. what can i do to increase my torque on my automatic g35
  30. exterior pillar??
  31. G35 03 radio goes silent after one minute, comes back eventually.
  32. Brother's G35 starting problems!!
  33. odd front strut noise
  34. Best Exhaust Project!!!!!!
  35. Staggered Wheels On an X
  36. 2006 G35 Sound System ??
  37. Tail Light Mod
  38. sunroof rattle 2004 sedan
  39. New '05 G35x owner
  40. OEM Shift Knob
  41. Just got back from the Tire Rack...
  42. I need a measurement!
  43. Audio system
  44. Will 19x8.5 5-114.3 offset 38 center bore 73.2 fit 2004 sedan?
  45. Does a remote starter screw up smart key igniton?
  46. Getting New Car!!
  47. what can and will go wrong after 60K miles? 2005 G35x
  48. Trunk problem. Help!
  49. so i test drove a 335i and a g37 coupe...
  50. 05 Dash Problem
  51. I'm NEW 2 THE SITE...Need to meet people ASAP..HOOK ME UP..
  52. New Owner!
  53. Anyone still on their winter tires?
  54. Winter Time Cold...
  55. vincenzg5 my car so far ...
  56. Fliped and wrecked my '06 G35X
  57. P0744...p1843
  58. Which WORKS? (playing around a bit)
  59. which wheels to go with..?
  60. My G35 got Plowed!!!
  61. Picked Up my '06x!!
  62. anyone elses G's taking a beating this winter?
  63. Looking to sharpen the image G35 sedan
  64. Is it me or does the throttle feel better when in auto vs manual?
  65. Rainy Day Fix. Clean TB, Plugs, Clean Plenum, Replace Valve Cover.
  66. new infiniti g sedan owner
  67. shocked
  68. DIY nismo rear lip install?
  69. Idle problem on 04 Sedan...help?
  70. Jdm double din CAGE?
  71. Got rear ended Tuesday night...
  72. Taking off my Rear spoiler and emblem this minute Pics inside Need little help
  73. Can this Wheel Bearing Be SaVed?? Pic...
  74. Took my car in for a few little quirks.
  75. Just bought my first g35, have a few quetions.
  76. Price to paint a mirror?
  77. 04 sedan heater only works above 2000rpm
  78. Please Help Heater Blows Cold Air When Warm Up
  79. Trunk arm lift broken....where to find a replacement :( - Pics inside
  80. My first question...
  81. oem alarm/alarm light
  82. Back in a bigger G, New from Utah
  83. Another new G owner, this one in Kansas
  84. New G owner from TN
  85. Oil level
  86. car starts then dies occasionally - runs fine and no engine light ??
  87. Removing Trunk Liner
  88. Do you need that metal ring on the cone filter?
  89. new guy with g35x
  90. cant keep 2500 rpm for smog test
  91. ? about 04-05 g35x headlight
  92. Bose Subwoofer OHM?
  93. what part is this
  94. Gas tank issue/sensor question
  95. spoiler i found.
  96. Totaled G35 Sedan??
  97. Engine air filters
  98. Another fail for the early 03 5AT Sedans - Sprint Booster doesn't work
  99. P1445(evap leak) engine code
  100. 2006 6MT Sedan
