View Full Version : G35 Sedan V35 2003-06
- Painted nismo oil cap
- Rim lip hitting fender ,HELP !
- Part name
- wiring help
- Should I Sell?
- couple of question
- Leaking valve cover, replace gaskets?
- Lightweight lug nuts reccomendations
- Thinking of mounting 215/65 R17 tires for softer ride...thoughts anyone?
- Battery reccomendations?
- Where to get small resonators?
- NEW!! Sedan Rear Aero Panel (Under Bell Housing)
- Creeking noise from front suspension
- hid bulb
- cup holder lid sticking
- radiator overflow bottle
- 04 g35x sedan drive shaft.
- Doriluxe/Strafe Trunk Question
- When it rains for more than one day, the key fob functions stop working
- 2003 Sedan shocks and struts
- KNS Brakes - Pads and Rotors for your G
- Bought brand new wheels and now im worried
- Dome festoon led issue ?!
- '06x Front Suspension Opinions - KYB Struts, Compression Rods, etc.
- 04 Sedan MPG
- brakes issue on my sedan
- Adapter to play songs from iPOD/MP3?
- new to the g series
- Snow button
- Plenum Spacer vs. Revup Plenum
- Calling out those with Quad projectors
- Rear adjustable headrest sedan
- How long have you owned your G sedan
- Has anyone ripped off the cat heat shields? Negative consequences?
- why not to buy Megan long tubes
- hard shift
- Vibration -Rotors and /or Ball Joint?
- NewB fitment question
- ANOTHER AIRBAG RECALL for the previous one !
- 03 Infiniti G35 Sedan Daytime Running Light issues
- PAC unit
- are rear toe arms need?
- sedan coilovers
- Help with radiator support clips
- Center Cap Part Number?
- hopefully not a reflection of sedan drivers
- Unusual engine sound. Help!
- Pumping Gas
- Tail light issue
- Car won't Start / Traction Control stuck off
- 2005 G35 brake booster line stuck...
- Sedan Console Divider insert
- Sedan Retrofit (SoCal)
- Sedan projectors...
- Osiris tune in AZ?
- Headlight's
- Alternator & Charging System, A Story
- Am I wasting my time with this early G?
- Clutch Question
- G35 coilovers
- Installing New Front Lifter Assembly in Driver's Seat
- 2003 g35 sedan seat swap
- Regular 87 gas used in Revup for 80k miles
- Why is the 03 so much better than the newer ones?
- 03 bottom trim mudflaps?
- 03 Infiniti G35 Sedan - Not a smooth drive??? HELP
- Water pump replacement how to?
- Wanted - DIY install for manual shift ring on 5AT Sedan
- ECU reset: Have you done it?
- Getting out of the first gen group
- MAF is done, need help!
- SS Brake Line Upagrade??
- Mud flap Remover 10mm
- How do I disconnect my AC?
- Coupe midpipe on sedan?
- Greetings from WI
- New X owner
- 2003 Infinit G35 - Where are the driver's seat controls?
- Rusted out muffler flange
- Totaled 2006 G35X
- How to sell my car (opinions needed)
- keep the gas tank full?
- Weird misfiring(?) issue??
- Does anyone know where I can find these tail lights for my G35??
- Better Support For G35 Sedan
- Do I need new rotors?
- power steering
- Compression rod bushings (issues after changing)
- HID woes
- 03 G35, 60K check up, what to look for?
- Tune up
- G35 2005 IPDM - Buy where? Help.
- TPMS LCD Display?
- cleaning your stock wheels?
- NASA we have a problem. The G wont start
- Slip light and VDC OFF ?!
- Minor repairs at the dealer: what did YOU pay?
- New member :)
- Instrument cluster lights?
- 2004 coupe seats in an 03 sedan, need help with the installation
