- Automatic G35's
- Lowered 2006 G35x Tire Size: 245/40R18 or 245/35R18
- Megan Racing Y-pipe on stock exhaust
- Code P0462 Fuel Sending Units Low Voltage
- Y Pipe bolts question
- Slight engine miss at WOT
- Climate control issue
- G35 & G35x interchangeable?
- cracking noise when turning left or on acceleration from stop
- Winter Tires
- Luv my 03 Sedan but hate slow rpms
- 03 Sedan Electronic Fan Conversion
- G35 Help..
- Anyone know where to buy a good wheel bearing/hub?
- Fake Nismo Bodykit?
- White smoke and overheating
- Engine bearings failed
- Did a oil catch can.. but are there any other oil sources going into the intake?
- 04 awd sedan front sway bar size?
- Best Looking Black Headlight Assemblies for 05 Sedan?
- Fast Intentions Gen-1 to Gen-2 midpipe swap. All i have to say is WOW
- Mid Pipe Question
- 155k Recommended Service
- Rattling when accelerating!
- Genuine floor mats?
- clicking noise
- Clicks when shifting into R and D on automatic
- ECU reset
- Help!!!
- N1 style lip install
- NRG Front Flat Strut Bar - Titanium -will it clear a spacer
- My 2003 G35 Sedan Needs a New Transmission, Please Help...
- Damn TPMS!
- Did you have your driveshaft and/or transmission go bad?
- Removed "power duct" no sound increase
- 03-04 nismo bumper
- Cannot Locate Part # Compression Rod BRACKET
- Seeking DIY instructions for sway bar endlinks replacement
- Wheel Fitment, need help on deciding offset/width
- 05 G35X Overheating.
- Taking engine apart
- Front lip instructions
- Not your typical overheating story
- Help with a cooling issue
- Car got keyed. Good time to change the color! Help
- CV axle re-booting
- Is this an HID bulb or a halogen?
- 2003 g35 overheating!! Need help!!
- Lumpy Engine sound
- 2003 sedan over heated...
- 06 g35 brakes on 03 need help!!
- Top Speed Coilover review
- 2004 G35X Lower Ball Joints
- Coolant bubbling and gurgling
- Need Some Advice On Mods
- Overheated, engine probably toast
- AWD question
- A crap shoot
- Doing my headers soon, bolt part numbers??!
- Pimp My Ride
- Looking for burnt ti exhaust tips for 04 sedan any idea?
- 03 136k miles getting 15mpg hwy
- Door panel the same??
- NAVIKS Smartphone Mirroring Integration Interface
- AC fan vibration
- Weird noise
- DIY: Install An Amp In 06 G35 Sedan w/ Bose
- rims for Brembo system
- Radio problems on hot days?
- Can A G35 Sedan Handle As Well As A Coupe???
- Dreaded AC/Radio Problems - Cheap fix?
- Windshield washer pump replacement
- 03 g35 sedan performance mods?
- Ac compressor
- Torn intake coupler
- 2003 G35 with manual trans? Fuel rec.
- Engine Splash Shield Question.
- Add Amp To Stock Stereo
- Front Lip selection
- What have you gotten covered under Infiniti elite warranty?
- Seeking clarification on adjusting coils (At least I'm trying myself!)
- New g35 owner here (oil concerns)
- Help with coils
- G35 vs Road Gator (Semi tread) @ 70mph
- creaking sound
- Do all 05-06s MT sedans consume oil?
- question about swapping out trunk from doggy door to 05-06 trunk
- interior body clips
- Recommendations for trunk bike rack for sedan w/OEM spoiler?
- G sedan revup with a couple problems p0300 + p0174
- stock xenon headlight problem
- Isni573 only playing for a few secs....
- Where is the in-cabin sensor?? ASAP
- Yes, another offset question.
- 04 g35x passenger axle
- Help with a jingling sound
- Need new Shocks!
- Seat Malfunctioning/Questions
- How to remove chrome door trim sedan
- Key Code
