- Thought i had a bad engine!
- Anyone Know What This Part Is Called From A Manual Transmission?
- Mostly goodby to my car
- 2004 G35 A/C Intermittent
- g35 sedan rim and tire size (FI)
- Help with HID Headlamps
- 3rd brake light
- Overlooked part of rotor replacement
- Rear sidemarker replacement mistery.
- Is this car missing something??
- Transfercase removal / AWD light is ON / C1204 C1210 codes
- AC Drain
- How to go about lowering my 05 X
- m2, megan racing or bosal y pipe g35x users
- 2003 G35 4 Door Sedan Door Seals
- Fixed inifiniti's brake design flaw with Nissan akebono big brakes
- Do the seats have limits?
- P0456 At Half Tank or Less
- Spark plugs look terrible at 36K miles
- Ignition issues with '06 35x
- will these tires and rims fit on my sedan or hit the front upper arm?
- Car sputters at idol after fill up.
- CV Boot Removal Front PASS side - inner
- Pass side CV axle interchange
- BCM going bad?
- Best sounding exhaust systems?
- Do G's have oval frame slot for towing "T-Hook"
- Should i tint my headlights?
- What year 350Z trasmission dipstick will work?
- Does the rear tires have toe adjustment?
- P2000 code after tune
- RB Trunk for G35 sedan (Is R1 Autoworks longer alive?)
- Just got a '03 G35 sedan
- Need aux in my g
- Spark plug conditions?
- 06 g35x
- Custom Shop Exhaust
- G35 Sedan Nismo Body Kit
- AC Works Sometimes
- No spark no fuel
- Factory Subwoofer not working
- Need Advice: weird spray/spark coming from left side of engine (video)
- Gas gauge acting up.
- Need advice: brakes are not working right
- R&D factory valve cover gasket???
- OEM Ride
- Newbie looking for sugestions
- Help on y pipe
- Seat compatibility! (Drivers seat)
- How to turn on the mile range?
- Valve cover change - Oil on spark plug - compilation thread
- Car won't crank when hot outside
- 05 sedan manual bye bye engine
- Spare tire
- why do we need camber kits?
- 2003 G35 Sedan vibration while driving and noise when turning
- My 04 G35x is for sale
- G35x awd front wheel bearing/hub assembly
- 06 G35X Sedan keeps blowing 40amp cooling fan fuse
- 2005 G35x Power tilt wheel problem
- rack and pinion replacement after problems thread
- G35x 5AT clutch replacement
- looking to lower my 04 g35x
- Oil Catch Can confusion
- ES Compression Rod Gap is NOT okay!
- Help! Rear creaking noise from my infiniti g35 2004
- Power Window Problems.
- Wanting to Buy a G35 (350GT) my events
- Radiator cooling fan assembly
- Projector retrofit on 06 g35 sedan
- Finally got my 6MT IP Sedan!
- What does "bump" mean
- Headlight question
- 3rd brake problem.
- No air is coming out vents; g35x 2004
- 03 Sedan, Help with Starting Problem
- G35 w/Mopar Oil Filter??!
- shock mounts
- 06 G35 Sedan. Want to Mod
- Decisions, decisions...
- nuts for studs on the catalytic convert
- Are bumps and potholes a problem?
- Jerking first and second gear 6mt
- how many x guys changed fluids trans/diff
- 2004 G35 In lock down mode
- Should I focus on tires, wheels, or suspension?
- Need rims help
- No start - No Crank - except if engine is Cool??
- Defogging the head lights?
- How should I clean up my engine?
- Front Camber Kits
- SES, VDC OFF and SLIP Lights - I know, it's the sensor!
- 2003 G35 Sedan Overheating
- What to do with a spare 2003 G35 Sedan?
- Rim option/color questions
- Can't read the dipstick
- Question about painting grille.
- AWD front differential roughness - bearings?
- New Drill & Slotted Rotors Thumping ./ Clunking Sound
- running ligh/low beam HID same as Fog light HID ?
