View Full Version : G35 Sedan V35 2003-06
- Strange HID problem
- Got hit by a Taxi cab today.....argh!!!
- Filthy rat in my engine bay! Anyone have a coil wiring diagram?
- 03 g35 air box filter setup
- Brake / Caliper question
- Camshaft position sensor
- 06 G35X Squeaky Steering Inside and Outside Cabin
- G35 lower control arms and ball joint - noob
- 2006 Infiniti G35x front end squeaking noise when turning
- 04 G35X Hub Assembly
- AC Condenser Fan Clarification
- Girl in need of help with G35 mods...
- Calling all 2003-2006 manual sedans
- Code 0011 but car is running GREAT
- 05 g35x coupe mid pipe
- AWD / X owners and Test Pipe help needed.
- P0345 Help!
- Grille Emblem Question
- 2003 g35 front lower ball joints question
- Code p1065
- Coupe Y pipe on AWD Sedan - less restrictive
- Added e46 m3 fogs to lower grills
- Rear and front differential
- Is this 2003 g35 sedan worth it?
- New here, and to a g35!
- 2003 g35 sedan wont start
- 05 G35x Eibach pro kit
- Front lip other than OEM?
- Clear corner question
- Rotora 2 piece replacement rotor question
- Starter keeps on cranking away!
- VQ35DE specific output not that high...
- Will headers and full exaust work from 07 coupe on 03 sedan
- '06 G35X problems this morning
- My '04 G35x AWD Sedan Thread
- Dangerously low oil
- Turbo Charging a 04 g35x AWD sedan
- OEM 19" Spacers?
- Advice on making HKS exhaust sound better? [Vids inside]
- New Ionic 05-06 G35 Sedan eyelids, roof spoiler and Gialla style grill
- Need help finding out what wheel size to order
- New Toy
- 2003 G35 Sedan, worth to mod?
- Noise right from wheel
- replaced clock spring now turn signals & headlights don't work
- muffler replacement
- Ignition off, car system stays on
- Is this weather strip on top edge of rear windwhield on all 03-06 G35 sedans?
- Gas gauge problems-do you fill your tank each time?
- 03-06 sedan thermostat different than 03-07 coupe?
- 2003 g35 sedan starting issues after being ran.
- 2003 Sedan, no crank and no start
- low idle/engine stalling
- anyone with autozone front axles?
- Mechanic needed in Chatanooga
- rear suspension bushings
- Sticky dashboard??
- G35 fan super loud HELP!!!!
- All the damn chrome
- Not Much Driving These Days
- First G35
- HELP. '03 G35 Sedan both headlights flicker!
- Radiator Swap
- AC Blower motor going bad,
- Nismo side skirt plastic clips
- Loss of power, no cel
- Crankshft Sensor
- G35 Sedan Exhaust Options
- Car vibrates on the HWY. Have others had this issue? What fixed it?
- Revier Mirror Covers
- Vdc button dial/potentiometer?
- Brake and battery light. Help?
- How to get rid of the Navigation and replace it with the stock packet
- My Big Fat Akebono BBK Upgrade Thread
- Sorry I Know this has been talked about. Need current info. 350z Tein stech on Sedan.
- When did you have to replace your original clutch?
- Audio Recording - Possible Wheel Bearing Fail? Help Me If You've Heard It!
- x sedan stock exhaust y pipe
- Interchangable V35 2005 Sedan Rev up
- Does anybody have any info on this g35?
- G35 oil change intervall?
- Vdc/slip issue
- Rear window brake light out
- Replacing doors on 2003 G35 Sedan
- Any Brakes pad & rotor review for 06 sedan
- Compression rod options
- Electrical Problems
- Should I change my headlight bulbs?
- Slight coolant smell
- Tokico brake calipers??
- eBAY Front Lip Installed on 2005 Sedan
- 2006 G35 Uncomfortable Front Seats
- New owner, not sure what to do.
- electrical
- My official goodbye.
- Ikon coupe lip on sedan
- What does this sound like?
- Steering wheel vibration
- RWD Engine in an AWD G35?
- 7 minute drive home, overheated, steam and coolant everywhere!
