- New exhaust install is SUPER loud....... But I Love it!!!
- Trunk liner rattling..
- TPMS Screamed in the snow
- How close are the fuel lines to the exhaust?
- Odometer/Mileage Light Not Working
- sound of the G!
- Thoughts on clicking noise?
- Won't Rev past 2250rpm after plenum spacer /stillen intake
- Air conditioning acting weird
- 03 sedan Projector advise/help
- 06 sedan Both fog lights out, help
- X Compression Rod questions.
- Low gas issue
- Headlight
- abs slip and vdc lights
- oem style ebay headlight retrofitted then filmed?
- !$1300 for mid pipe and muffler! 2005 g35x
- Yet another G35 overheating question
- Missfire with no codes
- I think I screwed up the BCM
- 03 track suspension
- Will sport shocks fit a non sport g35 rwd
- Do you guys also fill your air regularly?
- Front lwr control arm
- 2005 g35 engine shut's off and rpm drops drastically
- 2006 G35x Passenger Side Engine Noise
- Harmonic engine humm
- Heater issue - blows cold air when rear defroster turned on
- Question about Mid Pipe
- Wndow GO UP and 4" DOWN Problem
- 2005 G35 Sedan "Pings"
- How Many Quarts for Transmission Drain for A/T?
- 05 infiniti g35 coupe remote start
- INTRODUCING...G35 Aluminum Splitter
- Major 03 sedan problem!!!
- sedan Taillights Amber turn signal
- Engine Temperature Sensor Spun Around (Picture)
- x in the snow
- no dome lights
- Front passenger axle keeps snapping
- Driver's side HID headlight keeps burning out
- Anyone have G37 sedan sport wheels on an 05/06 sedan?
- Help with trunk handle
- 04 AWD G35x Engine Ticking? (Vid)
- High rpm.. no acceleration problem
- 05 G35x wrap in process...!
- Car meters and displays not functioning after Jump...
- Another 2004 g35 seat question...
- 2004 G35 Sedan Transmission Questions! Help
- g35 handling vs bmw 3 series
- Window Visors
- Window Closes then Reopens
- Coupe bumper conversion?
- Auto window up when car is shut off
- G35 strange rattling sound
- 2005 g35 sedan duckbill spoiler (fairly cheap)
- 2005 g35 alarm
- mass air flow sensor question
- Adios Muchachos
- Seat Switch Assembly... Lost part...
- My Moneys Worth
- Passenger Side Door Problems
- Radiator HELP ASAP
- Where can I get the lug nut lock?
- Car turns over but won't start -fixed!
- 2006x stalls
- 1 sec Rattle on startup
- Grill makeover
- new Y-pipe for '05 AWD??
- How to verify if sport package?
- 2004 infiniti g35 overheating
- Exhaust mounting: g35 sedan 04
- HELP! - Brake & Battery Warning Lights Won't Go Out!
- new g35 owner
- Fitted all weather mats- bug shield
- R35 GTR Clear Corner Fit G Sedan?
- JWT/z tube 160$
- Need to replace key fob
- Halogen Bulb Replacement!
- 03 G35 Sedan Leaking Fuel/Gas from Drivers Side Rear Wheel Area Have pics
- Roof trim failing
- anyone take apart their sunroof yet?
- Do I Need These Rusty Things?
- I finally got mine guys
- Droning Exhaust Note
- A/C only works when set to 60 degrees
- HID light installation.. please help!!!
- Is there a vendor that sells Hikkata Dori Nismo front bumper in poly here?
- DTC Codes
- Grill Replacement help!
- Do some G35 sedans not come with HID's?
- to buy or not? 180k miles
- G35 Bumper and Grill replacement
- HIDs
- Coolant temperature and Electric Fan operation
- ethanol
- Powdercoat stock rims?
- hey guys quick question
- HID replacement dilemma
- A/C on = louder engine noise
