- Random (baseball card in bike spokes) type sound on cold start
- Please Help. Codes P0011 P0021 on my 04 G35x
- DIY: 05-06 Sedan JDM Nissan Emblem mod
- 04 headlights flickering... need a bit of help
- Couple of Repair Questions
- G35x manual mode not working
- Steering Yaw Sensor
- Who has had a P1084 code before?
- 06 sedan aftermarket headlights
- Strange Creeking Sound
- 04 g35x please help
- rear license plate light bracket rusted to hell
- led daylights
- 04 G35 Sedan Wandering/Steering Issues
- Upper Control Arms
- Compression rods and relignment
- My Various Newbie Questions
- rim and tire help
- A Little Confusion with Codes P0327 & P0345
- Suspension Problem..Please Help??
- Should I sell my 05 G35x for a 2010 G37xS?
- Possible Limp mode with no SES light
- front brake maintenance
- Housing for remote key fob
- non engine codes stored?
- Replacement plastic for headlights
- KYB Shocks and Struts for g35x
- Poly front bumper for 04 sedan ??
- Help a car noobie save some money (some DIY help to avoid the mechanic)
- Need assistance
- Floor mat help!!!
- Compression rod aka lower rear control arm on 2004 g35x vs g35 vs coupe
- need help
- 2003 g35 Sedan with factory HID
- 11 Years Later... Highest Mileage G35 in the Planet?
- Finally happened, got ripped off
- Looking into getting neon lights installed inside my 2005 G35
- HELP!!! Possible safety issue
- Vis Racing 2004 Infiniti G35 4Dr Techno R Front Bumper
- 05-06 G35 Sedan OEM replica front lip now available in CF
- P0011-03 g35 sedan 6 speed
- Speedometer, tachometer, signals, etc. stopped working
- TPMS light on, how do I remove the bulb in the gauge cluster?
- 2004 G35 P0011 and P0300
- Fan comes on when OBD connected and key in start position
- fuel gauge issue - car stalled on hwy
- Burning Rubber smell when heat is on
- Bad Catalytic Converter or O2 Sensor
- P2135 VDC, SLiP, SES with no acceleration
- G35 2004 couple of questions.
- G not running right...any help???
- Manually move driver seat on rail?
- Opinions on best replacement parts for trunk strut assembly
- 04 G35 sedan Front Bumper Cover???
- Yet another dead battery thread
- Tail light fuse
- Windows problems
- Please help with Headlight Bulb replacement
- Anyone else's sunroof controls look like this?
- Coupe Cats onto an 04 G35x AWD?
- Staggered Rays on G35x
- ...bumpy ride
- Weird engine knock noise
- Tollboothwilley Transfer Case Shield Installed With Super Easy Directions!
- Looking to buy an 04 or 05 g35 sedan 6mt
- Considering a G35 (First Generation)
- Hissing noise '03 G35 75k miles
- G35 2003 - Horn wont stop! lol
- Buzzing noise under hood. Bad wire harness? HELP!
- Check Engine Light
- tranny mount?
- What type of cold air intake is best for a 06 g35..
- 04 G35x Engine Swap or valve cover gasket?
- VDC/Slip lights
- Clicking noise!!! Help!!
- car wont accept more than 3$ of gas at a time.
- Problems Starting my 2003 G35 Sedan.
- Rumbling noise & Intellikey problems
- Anyone here with a remote starter for their '05 X ?
- Headlight Replacement Question
- '06 G35x Squeal HELP!
- 05 g35x steering wheel making loud noise
- Car stalls with the high powered dryers at end of car wash
- ? for all with clutch radiator fans...
- Gas mileage normal or bad for g35x
- Infiniti Used Car Warranty
- Nismo or Kurookie 2003 G35 Front Bumper how will it fit?
- Navigation Screen
- Broken blower motor diagnosis?
- UK GT350 2004 sedan colour
- under door trim?
- Headlight Bracket
- Bluetooth module location?
- 2003 G35 Sedan Front License Plate Bracket
- Headlight Housings
- My exhaust sounds like a motorcycle
- Jack information needed
- Ready to send overheating G35 to the crusher!!!!!!!
- Why I did not buy a new G or Q50
- Suspension Noise
