PDA
View Full Version : G35 Sedan V35 2003-06
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
  1. Newbie AC Question - still blowing at 60 after hooking the hose up
  2. trunk will not pop!
  3. Im kinda stuck in an ugly situation..
  4. How hot is it where you live?
  5. Tire warning light won't go off
  6. Headlight help for daughter, please
  7. trade 26 inch 6 lug rims/tires for some 19/20s
  8. 03 04 05 06 muffler question
  9. Going to redo wheels.. again..
  10. Hr y on X
  11. wheel inquiry
  12. Nitto Tire launches mobile website
  13. TPMS sensor battery low
  14. need help w/2003 g35 sedan
  15. G-Force Front Bumper
  16. Changing center brake light
  17. need help with axxess aswc wiring!!
  18. Offset Question....
  19. Props to Tollboothwilley
  20. Is my Manual Transmission going bad?
  21. G35x Wheel fitment
  22. Just picked up my 2004 G sedan!
  23. black smoke?! help
  24. 03 G35 Sedan, whistling sound, PLZ HELP
  25. Would the maxima 2002 vq35 engine fit in our cars?
  26. G35x bumper center vent
  27. Plastic Push Pins
  28. Oem lip with nismo side skirts
  29. Picture Request: IP Sedan with matte white headlights
  30. Do I really need a camber kit?
  31. A/C noise TSB (ITB02-056b). Anyone have it done?
  32. Z-Tube with cold air extension... Good or bad?
  33. New member
  34. Coupe midpipe
  35. remove '05 front bumper
  36. Compression Rods Sedan vs Coupe
  37. The "Cam Position Sensor" strikes again
  38. Holy Cheap Te37s...
  39. Small Emergency. My result in violence against dealership. LOL
  40. creaking from rear windows...
  41. Now that I installed the 5/16 Spacer....
  42. Opinion on rims
  43. shifting feels different after spacer install
  44. has anyone had this problem?
  45. Picked her up from the dealer last night, buyers remorse this morning...
  46. Knuckle quesiton
  47. SES, Slip, VDC on after powder coating plenum
  48. coupe vs sedan Dash
  49. Things that break down at 100K miles
  50. Z front / coupe rear spring PICS
  51. Need heat before winter!!!
  52. anyone else have this problem??
  53. Will it fit
  54. FREE Driver Side Headlight Assembly Minus Shipping
  55. Anione try a stock
  56. cost/name/part number for lower engine guard
  57. Rear Wheel Bearings and Hubs shoot
  58. Washing car engine with pressure washer.
  59. what radiator options for A/T
  60. brake recommendation
  61. Make Engine Look Nicer?
  62. Headlight Question
  63. i have access to a 2003 coupe for parts
  64. How can you tell if springs came off 6 speed manual sedan
  65. Single or Dual Piston Calipers?
  66. Has anyone tried these????
  67. Help needed with bumper making
  68. Umm this would be great for Sedan
  69. Wheel swap - any opinions?
  70. First Aid kit????
  71. question about the G windows
  72. Spark Plugs HELP !!!! NO Pickup
  73. Need a little help on part sourcing...
  74. Clear Corners!!!! Again!!!
  75. 2 different trunks?
  76. mt fuji delete... = holes?
  77. Headlight twitches but won't go on
  78. Oil Filter Hassle
  79. 5/16 Plenum Spacer Bolts
  80. So The dealer wants to charge me $3300...
  81. Any G35x SoCal want a free set of Coilovers?
  82. g35x reflash
  83. g35x w/ test pipes?
  84. will plenum spacer void factory warranty?
  85. 100,000 - 120,000 mile Maitenance - Schedule, Suggestions?
  86. first and foremost it is an honor to be a part of this site and the g35 family.
  87. 2nd Gen on 1st gen
  88. stillen gen2 catback exhaust
  89. Which Front Upper Control Arm Will give me the most Camber?
  90. My G is really close to overheating...
  91. a/c fan speed?
  92. What the heck is this noise??? *video*
  93. arc induction box/suction pipe
  94. topspeed pro n1 exhaust
  95. 03 trunk on 04
  96. obd2 code info
  97. will this fit my 06 g35X
  98. Marry or not to marry, that is theee question
  99. Ouch!! Where is my front end?
  100. Bit of a Hate/Love relationship tonight with the G.
