PDA
View Full Version : G35 Sedan V35 2003-06
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
  1. Just hit 200k!!
  2. I am getting code P0304 which is a Cylinder 4 Misfire on my 2005 G35 Sedan
  3. AT Service
  4. 6mt Center Console Pics/Questions
  5. 'the heck is this??
  6. Grinding noise coming from driver side front brakes
  7. Check engine light due to HFCs
  8. Fuel Recommendation in User Manual confuses me?
  9. 2004 G35 Sedan SRS System
  10. Can anyone tell whats the name of this
  11. Adios
  12. Purchasing Control Arms (need help PLEASE) 03 Sedan
  13. Need help creaking noise coming from front drivers side..
  14. She is.....gone. :sniff:
  15. will this tire setup work for the x
  16. Car pulls left, camber not adjustable
  17. Evap system leak (large) and fluctuating gas levels?
  18. Help! Coilovers for G35x
  19. Autopage alarm & starter installed = Failed headlight?
  20. Sedan Trunk Dimensions?
  21. Rear Suspension Sagging, Riding Low
  22. Rear Wheel Bent In - Repair Costs
  23. High pitch squeak from engine bay cold start -recent cold weather socal
  24. Bodyshop trying to fool me
  25. Slip while turning left
  26. Open diff upgrade
  27. thought on this aftermarket bumper
  28. 04 G35x Wheel bearings !
  29. Headlight conversion question
  30. Cold Startup *squeak*squeak*squeak*squeak* - Belt noise?
  31. Tail light Shell...??
  32. Broken license plate light housing
  33. Door Light Switch Not Working
  34. Buy a lip or new bumper? 2004 sedan
  35. front drive shaft bad
  36. Rough Idle on startup
  37. Shaking when Applying Brakes
  38. G got crunched
  39. Strange idle with ztube
  40. Replacing battery
  41. Heating Issue
  42. Air suspension
  43. Give a gal a break....coolant question....
  44. Rattling from front pass wheel well - any ideas?
  45. Key Transponder Chip Programming (lost key code)
  46. Tiptronic 2004
  47. headlights
  48. TWM Knob users/ other aftermarket knob installs
  49. Duct Taped engine part!!??
  50. Rebuild Time?
  51. Camber wear or cupping wear on front passenger tire *alignment results picture*
  52. Where to place jack stands
  53. radiator
  54. Best way to shine the fender liner
  55. Help! No start no crank
  56. V-LED sale
  57. Interest thread for vented hood 05-06
  58. Wanna enjoy my G
  59. Overheating issue. Fan motor recall?
  60. Mesh Grill Question
  61. Slow tire leaks on 3 tires....ARGH!!!!!!!
  62. Car pulls sharply on certain highways..
  63. Help with cranckshaft sensor giving ses vdc off and slip
  64. 03 g35 drivers side seat switch part number
  65. nismo sideskirts and rear lip(or stillen rear lip) where can i buy this?
  66. I think I found my problem?
  67. Sluggish Acceleration?
  68. '06 6MT sedan compare (G35 vs. Maxima)
  69. 03 sedan muffler tips
  70. New Member from Quebec
  71. aftermarket clutch kits.!
  72. DRL bulb
  73. New Member Intro (06 G35x)
  74. OEM fan clutch high speed on cold engine?
  75. Newbee with some questions on my 2004 G35 sedan
  76. Has anyone painted the inside of their reverse lights?
  77. Anyone done wheel bearings....twice?
  78. Has anyone here done wheel bearings.....twice?
  79. Shift boot for automatic
  80. how do i get stuff out from under seats
  81. Strut tower rust
  82. Engine Shakes and Shuts Off at Idle
  83. Sway bar installation
  84. Car overheats when heater is on
  85. Remote Start Built In?
  86. Mildly modded 03 Sedan, what next?
  87. New G35 sedan Owner
  88. A/C Slushing Noise
  89. Shift Boot Insulation
  90. 2006 g35 reading Auto tranny dipstick
  91. Engine bay bolt dress up kits
  92. Oil pressure light comes on when I turn
  93. Sound when running over a crack and brake noise related with same sound
  94. 6MT Input Shaft Bearing Problem
  95. suspension question
  96. Stock passenger side HID Low Beam not working Help!!
  97. Hitting rev limit in auto-manual mode?
  98. 05 G35 Sedan Cruise Disengages Itself
  99. Radiator Options
  100. Gas Mileage Drop
