- 2003.5 Radiator Fan (I Think) Noise
- Blower motor noise
- g35x troubles
- Y pipe!
- Welding drivers seat bracket.
- Another overheating G35 2003
- Hr y-pipe, should I buy it at this price?
- anyone get a TSB done for free lately?
- Just Picked Up a G Baby!
- muffler delete???
- hose get hard but car not overheating
- Help! AC/Radio Do not work
- 2004 G35 Hard Starts
- 2005 G35 or 2005 G35 X?
- AC belt change
- OEM 18" Sport Rim Clear Brembo Front Caliper
- Request Bumper Repaint?
- Noise when turning right, dust shield?
- Sunroof won't open/retract
- Dtc 1759
- Gas draining fast
- Just bought a 2005 g35 i got some questions!
- G35x body kits
- 05' G35 6MT Gas Mileage
- P0303 Code?
- 2004 Sedan - License Plate light assembly rusted, and fallen back in to bumper
- Which struts/shocks match oem?
- Need help with coilovers
- Shock bolt removal???
- Happy friday the 13th....front driveshaft broke
- new g35, new quirks and questions
- New to the g35 game needing some advice
- 03 Sedan Passenger and Driver Seat Swap
- headlight concept
- Ran over debris, bent rims
- Request: BC Racing OEM Type Height
- I Need Help with my g35. Code c1131
- Interior lights malfunction?
- Headlight question....I know its been beat to death but I think this one is different
- HELP! Check engine light Code P0462
- Non stop problems, now my ac clutch broke off and broke my fan connector off
- solid or upgraded trans mount?
- How are you adjusting your SPC A arms?
- Future performance mods for my 2004 g35x
- Rear "true" coilover max height?
- Old Lady hit and run
- AC blows hot air
- Help with fuel lump
- Changing spark plugs
- Engine Misfire/Exhaust Sputtering?
- 2006 Mt lifter question?
- broken lower strut mount for trunk
- Need to find where to get a cam position sensor connector
- Does 2016 DVD update work on G35 2004 navigation?
- Need to install oem air intake!
- Coolant Spray in Radaiator Cap Area
- Changing gears roughly when engine is cold
- automatic transmission fluid????
- 2003 G35 Sedan bulb confusion
- 370z wheels
- A/C isn't as cold
- 2003 G35 Sedan Front Parking Lights Issue
- g35 issue
- Replacing Refrigerant Control Valve/Compressor Control Valve
- Help
- Fuel Gauge problem. really really mad now
- g35 sedan wheels
- Any suggestions on how to fix this?
- Q50 Eau Rouge wheels, opinions
- Left blinker light on dash not lighting
- White dots in clear coat on roof, what to do?
- Shaking only when I press the gas
- Throttle Body Hose
- EVERY possible thing that could cause low mpg?
- Early 2003 G35 Drive Belt Replacement
- My plan on upgrading the stock Bose system
- Need help with customizing.
- Keyfob
- Sedan vs. Coupe Suspension
- Car shut off out of no where.
- what sz tires to put on 19" rays
- New G35X owner... also need some help....please :)
- Quad wiring setup is killing me
- Cheapest I can lower car for properly?
- Widest offset for the rear?
- Officially purchased my first infiniti (2004 g35x)
- "Leather" Seats
- Dumb as* vibration please check this out i need some input
- Does anyone have a spare circuit board and buttons
- Alternator or fuel pump bad?
- Can Xenon G be converted to halogen?
- Sound system
- Procharger on 2003 g35 sedan
- Misfire
- Best wheel paint and clear coat for matte?
- Engine clicking sounds
- TIFU need help
- Help Shifting Issues
- hi every1
- Valve cover leaking into spark plug
