- Hit a man hole cover............fml
- Windshield wipers keep crossing!!! HELP
- What's the next step?
- Front Driveshaft Removal? 2005 G35x
- '03 Sedan dome lights don't come on when opening door
- Confused on what tires to go with!
- Seats ashy looking
- Troubleshooting Brake light + Battery light
- Will this donut tire fit my 2005 G35x? If not, where to get one?
- Recline seat swap help!!!
- Does the door panel come apart?
- engine "hiccups" 1x .. keeps running but no code comes up..
- High oil consumption on 2006 5at... questions..
- Fuel gauge problem. Detailed.
- 2003 g35 climate control and radio go out, but blower motor is on full blast
- Car won't crank interior light and hazards work high beams
- Girlfriend is now a G35 girl!
- P1084 Exhaust Valve Timing Voltage Circuit Bank 2 HELP
- Bumper ducts
- Car wont start after SES reset
- Rear License Plate screws won't come out
- Decent radiator for my 04 sedan?
- 19x10 +32 Within Factory Camber Specs
- headlight bulb
- tinkering
- New!!!!! to the 35....
- Looking into getting a new headlight projector and got a few Qs
- Antiseize on my sparks, like an idiot...
- Window motor/regulator 03 sedan
- Would 19" coupe rims fit on my 04 sport sedan?
- Vibrating wheel
- Undertray part number for 03 G35 sedan?
- Thump when braking
- BROKEN Rear Strut Tower Bolt
- Door hinge click
- Engine Knock and Ticking w/video 05 AT Sedan G35 VQ35
- Lowering my 2004 G35X
- VDC + Brake + Slip lights ONLY when it's cold.
- Loud Clunk Over Bumps
- Car won't start
- Hello, and thank you.
- Changed Car Battery...Now Horn Blares Intermittedly
- heated seat is not working
- New member need advice!
- manual mode 3 gear
- what brake pads to get?
- WOT lower power than 80% throttle ? Am I crazy?
- I purchased a salvaged 04 g35x
- Quick question on stock intake hose
- Window Tint Recommendations
- Can anyone identify this piece (pics included)
- 3M 1080 Matte Black Wrap for 2004 G35
- Does anybody sell the oem nismo rear bumper lip?
- Seat Swap
- '05 G35 sedan compression rod factory bushing install help
- Replacing G-Sensor in '04 G35 Sedan MT
- 2004 Infiniti Spyder Halo Headlights -- HELP
- Replaced Starter on 2005 G35X
- Wandering at Highway Speed
- G35X Dilemma
- Wheel Hub Assembly/Bearing Replacement
- lower arm replacement
- Need 04 G35X front bumper asap...options?
- Horn endlessly honking (video inside)
- High mileage transmission fluid change
- Car is unstable if I turn left at high speeds
- worth the purchase or no?
- Gas meter on odometer not working?
- Lines leaking water under passenger door
- Does 03-04 G35 Sedan Hood for 2005-2006?
- Dash cluster rpm lights dim
- New motor finally
- Shift Assembly, Correct Diagnosis?
- 2004 Sedan with Aftermarket Projectors
- What should my friend in Japan bring me?
- Need help with rim sizes on my sedan
- Car Accident- Nismo Bumper Trashed
- Anyone looking for jdm sedan clear corners?
- 2005 G35 Sedan Resonator delete
- time for a tune up?
- 2004 g35 sedan trunk release issue
- 05 G35 Sedan lung / slip while driving
- Trunk Popping
- Worth replacing?>
- mechanical and electrical fan question
- leaking water pump
- 04 G35x junk title
- APR CONVEX lens for sedan ever happen?
- Spare tire swap to 07 couple w/19s
- AP Racing calipers
- AC help
- Service Engine Light
- Steering pump going bad?
- 2004 g35x shaking
- vortech v3
- Oil ...?
- 05-06 front bumper that has better opening for intercooler
- Sedan to coupe front end conversion
- Newbie to the G35 Universe
- 2004 G35x Electrical issue with security system and radiator fan
