- Tranny grind in 1st/2nd
- Party soon coming to an end.....
- Gas smell - fluttering RPM's
- Transmission Curiosity!
- alignment question
- Coolant Leak & Oil Temp Rising
- Tune-up question
- Newcomer
- Camber arm Nut spinning!!! HELP
- Trailer hitch options
- USA SPEC PA11-NIS Not charging iPhone
- READY: PS 5/16”+TBS+TURBONATOR+Z-Tube
- Question about car stereo for G35 noob
- stillen rear strut brace
- Front license plate options
- 03 350z headers fit a 05 g35 sedan 6mt
- Help with my catalytic converters
- How do I remove driver seat? I need to redo a weld that broke.
- 03 G35 Sedan Ball Joint replacement ANYBODY?
- Doggy Door O2 sensors
- Severe Electrical issues horn +more doest work
- help with small cover in the trunk
- Questions about tuning.
- Windshield Tint Issue
- G35 tire suggestion?
- remove oe side skirts
- G35 2004 Sedan - OEM Exhaust busted
- Oh, Crap...my DL got stuck in the sun visor
- New to the forums and to infiniti
- Does your 5AT Sedan have an OEM PS Cooler?
- Key fob question
- code problem
- Proud new baby!
- z tube installed with extra vacuum hose
- Question about rims/tires.
- Is the coupe louder than the sedan?
- Compression
- Rear Spoiler Removal
- Glove Box Issue
- correct way to paint chrome?
- Need help with paint!
- Forced Induction w/miles
- quick question: jackstand
- 3 weeks
- Powder coating in WI
- Engine stalled at light, limp mode, code p2135
- question
- hey can some one help me???
- New G35 Owner!
- What are some good websites to find these parts!!!
- Junk in the trunk
- Megan arms
- 03 to 05 dash
- JDM Black Headlights Conversion
- Cigarette lighter issue
- Is this Normal? Both Fans Constantly Running.
- Ac shut offf
- Need new tires. Any suggestions?
- Skyline badges
- Remote Start Question (Viper)
- Painting Calipers... Black or Red?
- new to the scene
- Suspension fitment
- Front wheel squeak (05 g35X)
- Front wheel Squeak?
- SO Many Dings on my Passenger Side Door!
- Brushed "Aluminum" interior trim
- Stock Navigation not loading
- Help with key fob
- Having some trouble with clear corners..
- For you OEM GPS guys
- Popcharger = AC Problem?
- Broken hood hinge
- new owner with a few problems
- 05 sedan rims
- What are the 04 05 sedans going for at dealer auctions nowadays?
- tires still wearing after front spc camber install..what gives?
- Custom Exhaust Setup Question? 06 Sedan Catback
- Labor and parts thread
- Front passenger side rides lower than driver side
- Frame Damage
- ??'s regarding 06 G35 and extended warranty
- ATF Drain Plug Troque and Washer
- Next performance mod for the X...
- FCC ID # for 2005 sedan key fob
- Thinking about picking up a 03 Sedan
- Thinking about getting new struts and springs
- Need New Rubbers
- 03 sedan camber question
- Need your help. *Pics Included*
- 2003 G35 ac compressor not turning on
- So Im gonna paint my rims and calipers. Need your help.
- Would like your opinion on if SEAFOAM is right for me
- Window Tint Scratched?
- G35 Front Compression Rod Bushings
- Weird noise coming from undercar
- Too much rasp!!
- Official "Random Airbag/SRS Light" Thread: Lets find a permanent fix!!!
- 2004 G35x - $6,000 recommended services from dealer. What to do?
- Another magic application of WD-40!!!
