- 03 sedan debadge doggy door???
- Discolored Headlights Arggg What works best?
- HID fogs
- Starter Issues
- 2004 REAR window regulator reset
- G35 sedan drive shaft problems HELP!!!!
- 2003 g35 sedan
- Coin stuck in Arm rest latch, help please!
- I have a few questions about my new G
- Creaky drivers seat
- Recall
- Need Help ASAP
- Keep Lakeshore Slate or go Flat Black??
- Overhead console removal
- Front Diff, what tools to use?
- G35 Overheating issues
- market price for replacing passenger side rear window?
- filter question - stillen vs jwt
- V35 BCM gone bad?
- 04 Gas Pedal Sensor on a 03 sedan?
- 2003 G35 Headlight Restoration
- more ebay for the 05-06 sedans.. good or bad thing?
- Laugh at my pain (Muffler tip problem)
- Painting or Painted Rear bumper valence on 05-06 sedan
- Stripped allen bolt
- Driver Seat Stopped Moving Forward
- 03 G35 bogs down when starting hot.
- Where to buy a Aero/NISMO kit for my 2003 G35?
- Stiff/Rough Ride
- Wheel bearings again!!!!!
- Low Gas tripping CEL
- Dual Exhaust or just leave it?
- Dead in the garage - Codes
- sputtering around 4k
- Very rough going into gear?
- 05 G35 starting problem
- 2004 G35 Sedan AWD Agressive Wheel/Tire Specs.
- Need help/advice with either plastidipping or painting my grille
- Noise and vibration from 40-60mph
- Alarm Problems??
- Grill
- Oil Consumption Issues Solved?
- What should I be doing to maintain my engine at 111k
- Common rattling noises, loose heatshield?
- 06 G35x intro
- 03 G35 Sedan Wheels
- 04 Sedan---- Black/Blue smoke on start-up and when accelerating heavy
- "Boing" noise at 5-10mph after shifting from reverse?
- G35 sedan vs. G35 coupe midpipe (pics)
- Quick question about interior
- GF Performance Chip Kit for the INFINITI G35
- M35 vs G35
- 2004 G35 Sedan headlight question
- Do I have the worst MPG ?
- Faint constant "dial tone" sound always on - coming from speaker
- Radiator replacement on an 04X
- Speedy rims ?
- What is a transfer case?
- door trim replacement
- 2006 RWD Lower Rear control arm removal
- Car won't align properly, bent arms maybe?
- KuRookie
- Mod Installs
- plenum
- What to change my brake setup.
- Sedan brake confusion - Need some help
- 2004 G35X - does a coupe mid pipe fit?
- Newbie here. Need advice
- 2003 G sedan to an 2005 G sedan
- Ran on 1-quart of oil for over 800 miles!
- trouble with engine after z-tube &revup box installed
- What Car Charger do you guys use? 6MT Issue
- 05 Sedan Upkeep
- NEED HELP!!!! rear window defroster, drl, memory seat and trunk light not working
- Poor low end torque when cold. Belt-driven cooling fan?
- Just wanted to say a likely soon goodbye...for now...
- Redline SI-1 fuel injector cleaner procedures
- G35x endlinks?
- 2006 Rough Transmission. Help!
- How do you remove center mudguards?
- Stock transmission cooling with cooling?
- VDC light always on
- Going from 06 rear bumper to 04?
- Getting paint soon - should I use gloss black instead of matte black on nismo bumper?
- Finally found a G35x!
- Fuel Injector Cleaner and SES
- License Plate Light Bracket
- Starting to worry...
- wheel/offset gurus help needed
- some cd's dont play
- question about our "climate control"
- Crankshaft Position Sensor . . .
- popping/clicking sound at slow speed?
- Weakening wiper arm
- Brake judder or warped rotors??
- 2003 G35 Sedan help
- IPDM clicking
- Nismo Front Bumper
- MAF Sensor question
- Reflectors
