- Update On My Oil Consuming Road Whore
- Continuous Squeaking/Whistle Noise from front during any gear..noise sample included
- Dilemma...trade my 05G for a 2011 G37s??
- Resonated xyz vs Resonated HFC
- Exhaust Plan Layout ??
- Rear facing baby seats
- ART Pipes with otherwise stock exhaust?
- Moonroof won't close
- Help! Headlight restoration gone wrong!
- Please HELP! 04 g35x suspension help
- How i fixed my throttle body after cleaning it!
- AC blowing warm...
- Question about mufflers and exhaust pipes
- lent me wife the car and....you guessed it...
- Fixing door latch/lock cable
- 05-06 strafe nismo rear lip
- Stillen Or JWT ?
- Why did this happen?
- How much non-premium gas is bad for the engine?
- foglight fuse location?
- I have a 2004 infiniti g35X that i wanna lower HELP!
- Dual Clutch Transmission
- Nissan Matic S synthetic Fluid Vs Motul or Mobile 1
- Oil Change Interval For Short, Winter Trips
- Plastic Clip Fastener Differences G35??
- Would it look sick on my sedan?
- Leaking Oil
- odd noise from Driver side F wheel
- JDM nissan front grill with emblem on e-bay
- stillen gen 3 intake part # question.
- black seats For a 03 g35 sedan
- Sunroof barely works (help!)
- Where are you mounting amps
- Bumper install and paint estimate
- Best parts to increase 0-60 times
- how to remove paint from tail lights?
- Headlight plastics fogged up and brown
- Possible fix for shaking steering wheel/front end vibration
- help on lug nuts
- Debadging on a Black 04
- 5AT Transmission Help
- She's running great!
- oem 18" wheel setup help please
- vibration right rear wheel
- BRAKE, VDC and SLIP Light on - DO NOT NEED NEW BRAKES
- How long did it take you guys?
- im mad!!!!!
- Exhaust rattle under acceleration
- Crank sensor issues
- g35 sedan springs installation.
- spring replacement help
- Boost/F.I. gauges
- What is this?
- Front Seat Covers
- Finally got a g!!!
- 05-06 g35 with rev up ????
- G35 Sedan Matte White Vinyl Wrap
- Rattle in front driver's side, worse on bumps & the highway
- VQ35DE and VQ35HR tranny compatability questions
- Jerks/shakes 3 times when accelerating from a stand still & P0335 pending code
- Spyder Auto 03-04 G35 Sedan DRL Non-Factory HID, FREE set in SoCal!!!
- Fixin My G35 Sedan 1st G
- need help
- Wipers "catching" on intermittent
- Question(s) about dyno tuning
- Rockauto midpipe...any good?
- Energy Suspension Bushings
- Will g35 coupe TMPS work on a sedan?
- CF hood
- New to G35 Ownership
- Suspension Pictures Thread Idea
- Navigation CD.2004 coupe
- Upgraded my front brakes :)
- Need help! caliper bracket
- Life Expectancy of Stock (non brembo) Brakes
- G 18" Coupe Wheels question
- Any good shops in the chicagoland area?
- Getting started?
- Need this fast!
- R&D Valve Cover Seal Follow-up
- Tire size help?
- Coupe midpipe & hks muffler gasket question
- Where is the listing of common problems with the G's?
- Needed - One G35 Sedan 18" OEM Wheel :)
- C1142 - Pressure Sensor System - problem
- WTB:350z/Coupe Midpipe
- Weird lurch when i get off the throttle??
- Whiteline Compression Rod and Transverse Link Bushings?
- Do I need an aftermarket MAF for my injen short ram intake?...
- Car starts then stalls...
- Future plans for my G. What do you guys think?
- sedan w/ hks coilover HELP!
- 03-04 Nissan front emblem
- brake question
- Ice Ice Baby, Not the Vanilla kind
- Squeaking sound from brakes or bearing
- Pbj
- spring buckets confirmation
- Heat shield rattle?! Help!
