PDA
View Full Version : G35 Sedan V35 2003-06
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
  1. P0011 code and ticking sound on start up with newer timing chain and VVT Solenoids
  2. Camshaft Error p0340 on Drive Home
  3. 2006 G35 sedan on adjustble coilovers
  4. Soliciting headlight advice
  5. Best G35x Testpipes?
  6. Manual mode not working! How can I fix it!!
  7. Another “Did the backfire trick” thread
  8. No spark at all
  9. Front knocking noise
  10. New bumper
  11. 2003 G35 sedan
  12. DRL Issue
  13. Spark Plug Tube Seals - Fitment Question
  14. RPM’s rise & car push’s when letting off pedal coming to a stop
  15. Rev problem
  16. Weird knocking sound when A/C is turned off
  17. Key Fob
  18. 05 g35 sedan revup
  19. Replacement brake line
  20. G35x sedan radio unit.
  21. 350z exhaust on 06 sedan
  22. new member, 03 sedan
  23. Confused gears???
  24. New here, I need help PLZ
  25. Windshield Wiper Issues
  26. Valve cover bolt broke
  27. 5AT cold start rattle in drive and reverse (AFTER OEM CATS & Y-PIPE REMOVED)
  28. g35x cranks but will not start p1610/p1614
  29. Help! Oil leak
  30. Part number for radiator scoop?
  31. To Boost or Not To Boost
  32. Z1 Mount..Can you make you own supercharger? G35
  33. squealing sound when turning wheel
  34. 06 sedan rim and tire question
  35. 05 6mt rev up sedan , feeling sluggish and low power,help appreciated
  36. Rear shock bushing - removal and install help
  37. G35X 10,000 miles
  38. Need your help (Coolant Temps/Fan Clutch)
  39. Mileage/Transmission valve body and solenoids
  40. Transmission Crossmember interchangeable?
  41. Bell Raceworks Differential Brace
  42. Engine rebuild valve guides and valve seats?
  43. 2003 G35 Sedan RWD
  44. 06 G35 Sedan Random Clunk / Hiccup / Rattle
  45. How a Car Braking System Works: ABS, Stability and Traction Control Explained
  46. Problems with my 2003 sedan G35
  47. Mrev 2 advice
  48. ROOF LEAK / RUST. Cheap fix?
  49. G35 sedan stuck on limp
  50. New Member
  51. JDM 5AT Sedan Transmission Dmg End
  52. Loss of power - need suggestions
  53. Ztube
  54. Installing race seats
  55. Highway speed vibration fix.
  56. Low oil and rear main seal leak after storage.
  57. Will a magnaflow 14832 with a 2.25in inlet fit on a 2.5in inlet?
  58. Looking for transmission cooler kit or what to buy
  59. 2004 Sedan and 2008 Sedan OEM Interchangeable Parts?
  60. I need opinions.
  61. Auto with turbo
  62. [CA] Cat replacement
  63. Key FOB Housing [FCC ID: KBRTN001]
  64. Turbo 06 sedan
  65. Key fob problem
  66. How Power Mirrors Work
  67. 2008 Infiniti g35 sedan journey front lip
  68. P0300 Faulty code
  69. AWD ball joint removal
  70. Headlight Mod Opinions
  71. Front License Plate Options
  72. 03-04 G35 Interesting Dashboard Difference
  73. Loud cooling fan 03 G35 Sedan
  74. P1762 code
  75. clip for my gear shift knob
  76. counterfeit timken bearning?
  77. Belts
  78. Production Numbers/Rare Combo?
  79. Rear calipers: part numbers?
  80. Question about JDM double din(Link included for reference)
  81. O2 Sensor circuit issues
  82. Finished installing some bolt-ons, ops?
  83. Auto trans fluid check
  84. Please HELP heater and coolant probably
  85. NEW OCC Day for the G35 Perfect Fit!
  86. 03 g35 sedan overheating HELP!
  87. Need help identifying part that is leaking oil
  88. How long are oem side skirts on a 04 G Sedan?
  89. Brake light would not turn on
  90. Looking for options for new key fob
  91. Front hubs 05 G35x
  92. Is it worth swapping to black Interior?
  93. Shift Knob Remove
  94. What is This Part's Part Number (and Function?)
  95. Please help me to repair my car. I am on my own with this.
  96. 2006 G35x issues
  97. Wiper hose broken
  98. Mrev 2
  99. Goodbye project car
  100. Awd?
