- 18" wheel thread?
- does the flywheel on our cars absolutely need to be replaced?
- clutch and flywheel replaced for $1700+tax in sacramento area?
- Coupe springs on 06 g35x.
- Power steering problems after swanging
- Best oil catch can? All info is pretty old , wondering if anything new is out?
- 03 g35 starter not receiving signal
- May the force be with you...
- Missing interior panel
- Aftermarket projector headlights
- What's my car worth threads?
- Door Will Not Open!! Plz Help!!
- Tire probz
- Car Shaking Violently When Braking - Warped Rotors??
- Need advice on build
- Once proud G35 sedan owner not so proud anymore? Too many problems!
- 2005 g35x fuel sending unit question
- p0335 CKP sensor code
- G35 Engine code p0304 Cylinder 4
- A window problem different from what i've searched
- Vq35hr head on a vq35de block; is it possible
- Infiniti.Nissan computer for ECU, etc?
- Y-Pipe Studs - Easy to Remove?
- transmission shifts harsh when car is cold
- which shocks for daily driver?
- Transmission fluid dipstick level!
- Coilovers vs Lowering springs advice
- 03.5 6mt IP Sedan Stillen Supercharged - Who has one?
- sputtering when fans kick on
- 2003 G35 Sedan U1000 code also engine starter will not turn the engine over
- over 100K
- Need Help
- I need help with some oxygen sensor codes!
- Newbe exhaust question, NEED HELP!
- Hello everyone, just got my 05 g35 and I have oil questions
- Nj
- New to the G35 community and need HELP
- 05 Sedan to Dual Exhaust, Custom Job
- 2005 G35 Sedan Overheating Question
- 06-08 Revised 350z Springs
- Osiris Uprev Tuner with no ROM file
- Surely I don't need a new transmission do I?
- 04 sedan with obd 2 code P0300 & P0011
- Infiniti G35X
- Tein s tech
- Another 'car won't start' thread
- G35 Sedan Headlight Question.
- Need a rear bumper!!
- 05 g35x wipers gone crazy
- Lighting
- road noise?
- 2004 g35x exhaust question
- Aftermarket bushings for the AWD
- sedan black side marker
- AWD end links - 06 G35X
- Varrstoen ES1
- Removing Chrome window trim panel for repair?
- New Intelligent Key porgraming
- 5at rpm drop?
- 2005 Infiniti G35 V6 Modification Questions
- 265/35 19x9.5 Fitment
- Power loss after cleaning TB
- Compression Rod Squeak issue
- G35x Coilover install HELP!!!
- Exhaust swap from 04 350z
- Annoying Noise!?
- do you know this part on my G35x lower control arm?
- Car won't Start...Starter or Fuel Pump Issue?
- need help wit my g35
- Gauge Cluster doesnt Work and car gasping for air
- relative cost for tranny rebuild
- Upper control arm bushing into steering knuckle?
- Advice Needed - Help a brutha out
- no brake lights
- Is this right?
- So, apparently I was missing 3 quarts of oil???
- Can a bad control arm cause this?
- RPM's dropping with start - cause?
- p0102 help
- Need help with front sway bar links!!
- Just a thought/and question
- Another mod/performance question...
- Need help finding specific rotor size
- Cheap impact wrench is a must-have
- 06 G35X sedan won't shift into drive after losing clip
- hello everyone!!!
- What tires fit my wheels?
- What is this vent for?
- Ok, so no one has had this problem happen before
- What should i do?
- 06 g35 rear bumper
- G35X love it and Hate it... well not really
- airbag fault
- Weird explosion in my car!
- 07 g35 sedan springs on a 06 sedan? ????
- 2003 transmission problems
- HELP!!!Where to buy Upper Control Arms 06 g35X
- 04 SE oem front bumper License plate cover.
- New to Infiniti! Hi! and please help!!
