- Two punks slammed into my Rookie bumper.
- Tein Flex dampening reccomendation?
- Spark plugs have oil on them?
- Anyone looking for Junction Produce
- ATTENTION projector retrofitters!
- Air Conditioning Problem
- Steering Problems 03-06 g35 sedan
- DIY Advice Needed
- Spark plug gap?
- Trunk Lid Fastener Part Number
- Bose System Question
- stock alignment
- couple question
- hubcentric wheel spacer install question
- wheels!!!
- Emergency trunk release system
- 2010 G should i get a CPO? or no?
- Wheel Bearing Gone
- JDM Parts
- sad story this morning..
- Paint looks bad. What should I do?
- How will I know when I need a new clutch
- No longer a Drug Dealer!
- Kurookie bumper VS Possom aftermatch
- Tire size help for the M45 sport rim 8.5"
- rubber molding inside door frame coming off
- Need help with mods
- Transmission Fluid HELP
- Well...G35 is gone
- a/c compressor smoking = no cold air
- alignment question
- From an insane 10.8mpg to a mindblowing 8.7mpg -_-
- Interior Question
- best wheels
- Stretched tire PSI
- Considering trading for a WRX.
- The Perfect Mileage: It Only Happens Once
- finally put some coilovers on
- 2009 M35 wheels
- Big problem... SES light, NO power, engine not running so fine. *PAYPAL REWARD*
- New to the forum and owning a G
- Weird noise from under dash board passenger side
- unwanted exhaust smoke? problem?
- Test pipe o2 sensor help!!!!!!!!
- Finally!!!
- Hot Air from vents
- rear windows fuse?
- need help !!
- 1 ignition coil shorted out, should I replace them all?
- Question about coupe seats in 03 sedan
- Just bought a 2003 g35! (Slip,VDC off, ABS) problem
- getting test pipes, few questions
- z/g combo
- Trans drain and fill
- Alarm problem
- What the hell!?
- Megan racing or bc coils for my 04x
- OBX Exhaust ???
- Oil Cooler Relief valve location?
- Top Speed Pro-1?
- BC Coils with GTSPEC FSB clears/fit?
- passenger side fan
- Is this causing a rattle?
- LED License plate bulb info?
- my g problems
- 350z suspension on an X
- Bc coilover squeak
- Help! This light is stuck on
- A pillar water leak
- xxr 526 or 522???
- Auto vs 5at
- How to maintain A G?
- Help me decide Which Finish
- 350GT Parts and badges help
- Changing From 5W30 To 10W30
- Tire and fitment question
- 350z oem cat back on g35
- 3.7FD assembly!
- 143K Miles on a 04 Infiniti G35x too much ?
- Photoshop Request - Gold Rims
- V35/G35 sedan wheel/tyre setup
- Where do I buy interior parts?
- Dumas move of the day
- 370z Y pipe on 05 Sedan ??? Read sooooo much on 350z Hr
- 2003 G35 Belt replacement parts simplified
- whats the best coils, for under 1000
- 60k maintenance
- Upgrades for 2006 G35x 5AT
- 350z midpipe = coupe midpipe?
- Sedan Community I need YOU!!!!
- Control Arms + Tie Rod Repair Quote Question...
- Weird Power Seat Issue, please help!
- Long Distance Inspection
- Roll'n on 26"
- HKS Exhaust!
- Front Marker Light Bracket Swap
- dead battery after taking it out of storage/issues now
- QX56 Mt. Fuji Rear Emblem Installed - Debadge and Rebadge!!
- Powder Coating Question
- one clunking sound on cold start up
