View Full Version : G35 Sedan V35 2003-06
- Need help ASAP
- Engine Running Lean (P0171)
- SES (CEL) Light issue + instrument cluster
- Vq25dd egr
- More headaches
- Trunk release button in glove box broke please help
- Rack or Tie Rods
- 2006 G35 - potential good buy
- Differential Vent Question
- 2006 Infiniti G35 Sedan Fuel Pump Question
- Can this be repaired?
- 2022 G35 Aux Install
- Seat Covers for Back Seat of G35 Sedan
- 2005 g35x awd
- Tightness in certain spots of steering
- 05 G35 Bose subwoofer upgrade
- Timing Chain Rattle Replacement Cost
- 05 G35 Cruise Control Light won't turn on
- transmission/CV noise ? any ideas
- 2004 g35 sedan fuel guage
- First time I've ever bought new wheels for a car
- Speedometer not working at
- Walbro 450 in sedan fuel pump assembly?
- high idle 05 g35 sedan
- Need help finding out what’s wrong with my radio
- '05 Sedan 6MT No Crank No Start Issues
- 2004 G35 sedan problems
- Help identifying an unknown wire.
- Intermittent overheating help
- Tell me about my car
- Been Awhile....
- Troubling chirping and rattle from engine bay
- Suspension Clunk
- Knocking Noise!!!
- Problems starting after doing pop glitch
- TRansponder key busted
- 200,000 miles and I still have the original clutch!
- Slip light
- 08 M35X exhaust on 04 G35 RWD sedan
- Seat switches
- parking brake switch replace
- Idle relearn
- Winter Tires, running Blizzak WS-90s
- 19 inch rays on lowered sedan
- Vdc/Slip Lights on...
- Brake Bleeder Screw Leaking Around The Threads
- Which 75mm throttle body?
- Strut tower
- 75mm throttle body
- Z1 vs motordyne plenum spacer
- Throttle body and plenum spacer
- 2006 G35 Sedan
- Suspension
- Amp overheating
- Is anyone else having batteries needing to be warranty replaced a lot?
- G35X manual tranny swap?
- 350z de motor swap into g35
- Crank but no start
- Where to Buy Fuel Pump Relay???
- Vq35de swap
- Keep Dot4 Or Change To Dot3
- G35 Code P0603 ,Transmission issues , Slips in drive
- 2005 Infiniti G35 Sedan Questions
- Repair? Sell? Keep?
- Rev up to de swap
- 2005 G35 Sedan No Start, No Click, No Crank
- 2005 g35 front bumper
- Auto to manual swap handbrake question?
- Starter cables melted
- Know any Auto shops in San Diego ?
- Rough Idle, Sputtering, Limp Mode (kinda)
- 05 ignition switch replaced
- Yellow and Red wires connected together G35 2003 Bose
- G35 dripping a lot of water
- 2003 g35 sedan
- Limp mode with warning lights, but no codes
- Transgo Shift Kit - Cold Weather Reliability
- The state of my 2003 G35 in 2021
- Aluminum under tray, which one?
- Solving my overheating issues to start off my build.
- How to know that car has hids before i buy.
- Rack and Pinion Vibration
- Reading the Transmission Temperature
- Odd idle issue
- Slight movement play on steering...is it normal?
- Rod knock
- Slommy Build Thread
- Never going back to the dealer smh
- water pump & overheating
- Broken Drivers door exterior handle
- Key will not turn - its complicated
- Highest mileage?
- 2005 G35 Sedan B-Pillar OUTSIDE molding part numbers?
- 2006 V6 G35 strong fuel smell in plenum
- Starting Problems
- 06 G35x front left area clunking over bumps
- Reprogramming after engine swap
- Oil Leak above Passenger Suspension
- SES light won't stay on
- Hello and a few questions
