- Trunk lip
- 06 (1st Gen) G35 sedan to G37 IPL front conversion
- Swapped the Engine in My 2004 Sedan In My Driveway!
- Navigation won't stay up
- Squeaks and other noises
- Battery problem
- Another car won't start thread.
- Clicking sound when out into reverse
- Tanabe df210 vs Tein s Tech!?
- will tein coupe coilovers fit a sedan?
- 2003 350z springs on a 2003 sedan
- Squeal under hood at low RPMs has turned into chirping
- Thunk going from P to D.
- eyelids for my 03 sedan
- aftermarket upper control arm bushings
- Running hot
- Cleaned up headlights!
- Evap valve impossible to put in
- 03 rough idle flat on the highway
- Driver Seat Side Airbag Problem
- Another Wheel Question (Rohana RC10 or RC7/Niche Verona/Vossen CV7)
- What the frick is the sedan parking light
- idling problem
- ideas for rims ??
- Hard Shift from 1 to 2 Gear On Cold Start
- Clear side markers
- mobdoo
- Alarm rings EVERYtime getting in or out, Reprogram??
- Need help
- 2005 g35 POWER STEERING CAP!?
- Can anyone recommend an air intake?
- DIY for replacing oil pump?
- Mystery Green Wire Connector
- service engine soon light on
- Vibration and kick coming from rear
- Custom intake located behind front grille, similar to the G37 Stillen kit!
- Houston Custom & Performance shop
- Very elusive front end clunk
- Opinions on Nismo front, 06 coupe lip, with a carbon fiber splitter?!?
- 2005 G35x Manu-matic Working Intermittently
- Antenna issues
- Wheel bearing after 30k miles? 2005 G35X
- rattle
- 2005 - 2006 G35 Sedan interchangeable parts
- 04 G35 Coupe 6 speed handbrake.
- Installed Grounding Kit.. Wow, what a difference!
- Centric Plain 120 Series Rotors.......any good?
- Ac wont turn on
- Overheating
- another tire thread :) question g35x
- Aftermarket spoiler brake light?
- Need brake pad recommendations.
- Start up issue - Video included
- Rear axle click is back
- Navigation DVD Drive
- G35 03 sedan control arms need replacing
- How to take *out* the cup holder ?
- G35x suspension question plz help
- Squeezing out the Ponies
- Strange I-Key Fob Issue
- Suspension/Steering Issue
- Hello
- Help fast
- Help with wheels. Opinions needed. ALL
- Installing OEM Spoiler..Need Measurements
- Whats my Whp going to be?
- 05 Sedan with G37S/Q60 OEM 19"??
- Is this better than HR Y-pipe?
- steering wheel power tilt fail
- ERROR code -P0150 O2 SNSR CIRCUIT-MALC(B2/S1)
- Tires
- Tires
- Normal oil consumption
- drivers side power seat stuck
- Going up in tire aspect ratio
- Did i replace the fron wheel bearing ?
- Sunroof leak?
- HELP!!!!! Wrecked need parts list
- I need help on a/c sensor I don't know where to buy it online?
- My new front Timken wheel beering failed after a week.
- Fan trouble! Help!
- Air intake tube diameter size?
- vibrations braking from higher speeds.
- g35 sedan offset
- Gear Oil
- Valve cover leak
- M3 mirrors
- Replacing Compression Rod
- 350z anniversary rims 5 spoke
- P0430 this morning. Need help figuring out
- Any good body kits for 2005 Infiniti G35x?
- Steering Radio Controls
- Nitrous Express#744-60000 Or NOS#741-05029
- dead spot, power stutter at 3800rpm 5at in manushift mode
- Quick question about the ECU Reset Procedure
- can I put a 2005 engine in my 2004 sedan
- Sending Unit/Pump question (not about q-tip)
- Clear difference with OEM MT fluid
- G37s wing project on the Frankenstein sedan.
- splash shield help
