- Driving tips
- Suspension on this car feels... squirmy?
- whos is thiss??
- Should I get this Mod on my G? Is is worth it? Any of u done it?
- HFC Vs Testpipes
- Evo-r.net is a scam
- Big Brake Caliper Color?
- Replacing Upstream o2 sensors from the top?
- Long Tube Headers vs Equal Length with ART Pipes
- Compression Rod Question
- G35 05-05 cluster in my 03
- Megan resonated test pipes
- would you buy an 04??
- (Electrical Problem) - Infiniti g35 Coupe - Dash Flickering?
- Quick question
- Looking at a g35 coupe, opnions
- 04 G35 Coupe 6MT wont start
- My 2005 Automatic G35 Coupe
- concerns on 2005 g35
- Competition clutch stage 4 clutch & flywheel
- Godspeed?
- G35 22 hour Road Trip
- Wheel Color Opinion
- is this a 06-07 sport sideskirt
- my G
- Stillen exhaust
- Tire Size
- Which should I go with...advise plz
- New G35 owner with questions
- 04 G35 Coupe, Cluster
- FS Genuine Volks Time Attack 19"
- All out with a new tranny or just repair it
- Anyone ever use Dr. Color chip??
- 07 G35 coupe
- Alignment Redone?
- Fuel gauge going back up while driving
- Help - My reverse lights don't work but bulb is fine...
- Can i run 255/45/18s on my stockers??
- How would this setup look?
- Larger tires and wheels
- Another farewell thread
- Fix for broken third brake light
- Replacing 2003 coupe headlights
- Decibels Level? HKS vs TDX v2.
- HELP! Failed Smog
- Front wheel bearing replacement
- rear license plate screw hole section broke off
- Anyone have problems with LED's screwing up their radio?
- Rattle from the Rear...
- Sand/rocks in my exhaust?
- Dont let your Brother work on your G
- Buying is exhaust is exhausting!! Help me!!
- 2006 G35 Coupe Sport Package???
- Going to the Stealership...thoughts
- Headlights...04 to 06 coupe swap?
- anyone installed a aftermarket underhood/splash guard?
- Exhaust Question HR or Nismo
- HID Reverse Lights?
- Eibach Springs
- How are my alignment specs?
- Projector Shroud Size
- Collision damage~!
- 30mm spacers
- Momentum performance vs crawford z headers?
- Tire Pressure sensor
- Overheating
- Chipped Bumper...any ideas to fix?
- coolant tank and steering tank
- 04 g35 problems with tranny, clutch and flywheel
- Ummm I found this under my drivers seat
- Anyone know where I can get this bumper?
- Headlight Ballast smoking and clicking loud
- So many bolt-on's but so little dyno HP - Dyno Vid Included
- Third brake light has a mind of its own!!!
- 2003 G35 Coupe White on Black, Premium w/ Navi
- Rasp galore with new Berk HFC’s - Video Included
- Beast...
- Just bought Varianza T1s wheels 20" and want to know if I can lower my G now?
- GReddy Turbo Ti-C Exhaust
- Help!!! Slave Cylinder not pressing fork all the way back
- Element Wheels
- De-badging question
- Paint my piping?!
- Best Lowbeam HID with tinted Headlights
- WTF is this!!!!
- So I finally stop slacking after 2 years
- Flickering HID's
- Trapped Water Sloshing Sound? Huh?
- 03 manual coupe acceleration problem
- Opinions on Issue With Strafe
- Does anyone think it's gay if...
- Actual MPG not matching NAVI INFO screen!
- VCD + SLIP after shifting gears
- Is this the right product for Tanabe DF210?
- What can I use my OEM Nav screen for?
- Wheel Weight and Performance (looking for prior experiences!)
- 06 G35 Brembo's?
- I need Exhaust help :9.
- Texas State Inspection
- Burnt plast smells bad.
