- RPM fluctuating after shifting gears
- Manumatic/Triptronic and modifying the engagement?
- getting tranny replaced...problem
- 2003 Coupe Rear Humming / Buzzing noise
- Newly boosted G = fried stock clutch
- 4.08 gears or ecu upgrade
- Tranny fluid change.
- Clutch Depression Squeak
- Burning smell.. possibly clutch?
- 03 tranny grinding noise
- Clutch will not go in
- Problems with Auto Tranny
- external auto tranny cooler?
- Ralco RZ Short Throw Shifter
- Refused to shift into 5th?
- Valve Body Upgrade- Core program
- can standart auto transmission work with 400 hp
- B&M short shifter
- Question about differential oil change
- Will a 2005 transmission work in a 2003?
- Is it necessary to do trans. flush at 30k mile?
- Chaning Transmission Fluid
- P1716 code. Tranny
- Auto Transmission
- is there a "j-mod" equivalent for our cars?
- Need Help Clutch Pedal!!!
- A quick way to determine 6MT transmission revision
- Changing 6MT Tranny Fluid
- Royal Purple oil/diff/tranny fluid
- Fluid capacity Question? Diff. Tranny???
- I can't drive an automatic !
- Drifters...question about LSD...
- New Clutch Masters clutch/flywheel--install w/ pics
- Question on manumatic?!?!
- info on a awd swap for a coupe?
- DIY: Changing Clutch
- New to the group and have a question
- Nismo clutch installed....but car makes noise...Need Help!!!
- 5AT gets stuck in manual mode
- Transmission and Rear Diff - Dealer doesn't use washers?
- Manual transmission owners...
- Which clutch are you guys running?
- Easing that 1-2 Shift.
- clutch/fly install, noise (not chatter, like loose bolts in a coffee can)
- differential oil question for g35x(05)...
- 2007 Coupe 5AT Valve Body / Dealer Service
- Changing My Clutch On Saturday
- anyone else have a squeeky clutch pedal?
- Clutch Problems...HELP!!!!!
- What transmission fluid are you using in the G35 6MT?
- Anyone used/heard of F1 racing clutches?
- Clutch is stuck to the floor!
- Clutch/Flywheel Noise after upgrade.
- Shift Issues
- What Flywheel?
- Can the flywheel on an 06 be replaced without dropping the enigine?
- Rough shifter? help!
- Is there a difference in noise from the "flywheel chatter" and the Throw out bearing?
- HELP - Squeeking clutch
- Brand new JWT clutch/flywheel setup + new tranny!!
- G35 clutch issue
- I have an 04 6mt, whats a good flywheel and clutch to replace oem?
- Quick Tranny Question
- tranny fluid
- First time ever driving on a after market clutch/flywheel. is this normal???
- 05 6MT - Trans / Clutch Issues
- So I ordered a new clutch...
- Clutch squeeking.... question
- Fully Disengaged ?
- Semi-emergency- Whats Wrong With My Clutch???
- Question about my clutch..
- G left me stranded...dead clutch pedal...
- 6mt Transmission Problem
- New Engine will be here on Friday & need clutch advice!?!?! PlZ Help!!!
- 5AT Transmission Problem
- clutch fluid
- problem with my Automatic Transmission
- Nismo Pilot Bearing
- Want a new clutch
- 03 Coupe 6SPD tranny problem
- Automatic to Manual transmission?
- Transmission problem?
- one wheel wonder?
- Humming noise when moving from stop
- JWT Clutch and Flywheel
- Tranny- Flush or Drop Pan?
- rear diff gears on a 5at!?!?
- New auto tranny mod might be avail (tcu mod not VB mod)
- tranny problem
- Revo Technica Short Shifter
- Hard Shift Is it Normal 5 A/T
- Lagging trany.
- which clutch and flywheel?
- Is this the clutch "sticking?"
- Anyone get a fix for the notchy shifter?
- 2 little questions! :D (clutch questions)
- Have a clicking or ticking noise coming from tranny
- Anyone switched to synthetic transm 6MT oil?
- Rear diff oil weight
- Automatic Transmission Upgrade options?
