- Stop laughing - Need help - remove valve cover/drop oil pan/do nothing?
- Help! What is wrong with my car?
- Problems with A/C compressor belt coming apart?
- Coolant change help
- Questions: Calling the Gear Heads
- Spark Plugs...
- trying to install oil pressure gauge, where does it plu ginto at???
- Need help finding a black driver side seat. junkyard?!
- slow speed steering effort
- Spilling Oil
- Oil Changes....... =(
- Engine hitting my chassis?!?!?!??!
- FI Test Pipes/HKS Exhaust Clips.
- Plenum Spacer Install
- Hood liner... do I need it?
- 350z Engine Cover
- IAT & CTS Sensor
- smoking too much after turbo install
- B&M Shifter Broke!
- more power
- Skunk2 Plenum Spacer-(5/8")-
- high flow cats
- 5at w/motordyne spacer vs. stock 6mt
- Problem
- Problem
- HELLLLLLP!!!!!!!! Check engine light!!!!!!!!
- Spacer question
- changed to royal purple
- next step
- Strup Testpipes installed, Video...
- Overheating issue at MAM roadcourse! HELP!!!
- APS exhaust or stillen?
- Vortech Problem!
- engine spec help
- shifter parts
- LF Aftermarket clutch closest feeling to stock
- Fugi cat-back sound clip
- stuck in neutral
- How much do you guys pay for your oil changes
- K & N Filter on a 2007 G Coupe
- Having Big Problems!..
- Oil question
- amsoil
- Question about Wideband sensors
- Anyone see anything missing here?!?!?!
- Question on mods and adverse effects.
- turning off ac manually?
- ecu reset
- AMS Radiator
- Kinetix V+ Plenum VS. Motordyne 5/16 Spacer kit???
- Motordyne 1/2" Spacer VS. 5/16" Spacer, SOUND???
- Serious Brake or maybe Throttle Issue - Near Crash
- Install paddle shifters?
- Just an idea...
- SOUND CLIP OF THE NEW Xo2 Exhaust!!!
- Car Doesn't Want to Start
- injectors
- Oil problem
- $390 for ztube/popcharger, and UP Crank Pulley good price??
- New G35 coupe Xo2 Exhaust clip sound!!!
- valve spring compressor
- Honda Question
- Project Help, All Motor 500+hp
- belt help!
- purolator filter review
- Spacer Help
- Flashing Check Engine
- Car starts then dies
- Coolant on belts
- key fob
- turbo or supercharger
- Happy Day. Pix.
- Feedback and Questions on test pipes
- Ramps
- HELP> I cant open my hood..the latch is not disengaging
- mrev spacer
- wuts the difference
- turbo kit on ebay
- Stupid question re Motor oil
- Cold Air Intake and Other Mods
- Supercharged or TT 5at sedan?
- Baseline Dyno '04 G35 Coupe 6MT
- Has anyone used Extrude Hone before?
- pinging???
- What kind of real-world gains...
- NEED HELP, On Oil! Quick Question! 5W30 or 10W30 and synthetics???
- Nismo Power Steering Cooler--pix.
- Downpipes
- Hp Increase?
- new engine ?
- helppp....reverse will not work
- 5AT- APS adaptor
- Pulleys owners: how's the NVH?
- Pop Charger Z tube
- EMANAGE, UTEC, ECU flash?
- new to forum: Old G owner.. Question Rattle\Not clicking. From rear end Not interior
- really....
- ECU code 21? Is that what these lights mean?
- Blue smoke on startup...
- for NY 5w30 or 10w30
