- Help with JWT clutch while the car is on lift at Dealer!!!
- FD for 5AT 12-03
- Skaken car PLEASE HELP FRIENDS
- Shifting between gears feels harder?
- Squeaking clutch pedal
- Burning smell after driving..
- Shifting...a bit "loose"?
- shifter shaking in my G35 06 auto
- 2005 G35 Coupe 6MT engine noise help???
- whats the drivetrain ratio % for an 04 G35 AT/Coupe?
- hacking ATTESSA
- Thinking of doing drain and fill on my transmission
- 4.08 or 3.9 gear for 06 6mt ???
- Bunch of noises
- 1300 dollars for a clutch WTF
- Rear end whine/roar at 60 mph
- Clutch distance
- Clicking Noise coming from rear tires?
- clutch/flywheel
- 2nd gen 6mt on 1st gen coupe?????
- carbon fiber driveshaft???
- Does the clutch adjust itself
- Transgo Shift Kit
- G35X Transfer Case Bad
- Question : What clutch and flywheel?
- Torque Converter
- Swap 6mt tranny to a 5at
- Clutch Slave Cylinder
- Anyone know how to install upgraded valve body?
- G35 6MT: Loose feeling when driving. Normal?
- Dealer tells me I have to get a new clutch
- tranny problems
- Will 04 sedan transmission fit 03 coupe?
- Driveline Shudder
- Diff theory: one wheeled burnouts
- Slight rattling noise after accelerating from 2nd gear?
- Is there a DIY for an AUTO transmission fluid change?
- New eneos diff fluid car feels weird!
- linkage
- Help with clutch/flywheel decision
- Crank Positioning Senor - HELP!
- bad bad vibration
- help with transmission
- fyi: matic j has been replaced by matic s
- Lost 5th AND 6th Gear?
- Whining noise in my gear box
- Fly wheel out of balance - that's normal?!
- Clutch Slipping, other problem besides clutch wearing out?
- wierd clutch pedal
- Winding noise between 2,000-3,000 rpm
- Putting gl-6 in the tranny good or bad???
- Question for those who have changed their own clutch
- Manual tranny noise, rattle, normal? 06 g35
- NEED HELP! does ur 6 m/t do it?
- aftermarket Flywheel and Clutch
- After RE short throw install
- LSD for the coupe?
- Clutch install tomorrow!!???
- Valve body Upgrade
- chattering noise
- tranny problem or clutch?
- chattering noise
- installing short throw shifter, difficulty
- If I install a LSD
- 6MT Problems Help!
- Matic-J vs Amsoil for the tranny?
- Ordered 350evo Rogue
- Can the 03 6 speed tranny take GM Synchromesh?
- DIY Front Differential Gear Oil Change
- 2003 '03 AT Sedan 93k miles - Dealer told me I need new transmission
- Which is the best LSD???
- ___competition Clutch + Flywheel Combos_____
- Yet Another Clutch Replacement Question
- another "what clutch" post
- Another clutch warranty question
- tranny cooler capacity
- 6MT Shift linkage rattle and sticky gears
- Sticking Clutch Pedal (bad clutch???_)
- How much power is the 6MT limited to if going FI?
- What do you think of this clutch flywheel combo?
- problem with cold start into first and reverse.
- 6 puck too agressive??
- Car will not change into 3rd gear going up hill
- Will this ACT clutch fit a 05 coupe?
- whats that thing called?
- Clutch Question
- which clutch?
- Clutch warranty question
- Shifter Vibration
- New Fly Wheel+New Clutch/New Pressure Plate= Loud Rattle
- Clutch Problem - Help
- sticky JWT clutch!
- Downshifting / Engine Braking?
- clutch pedal
- Manual Tranny and Diff Fluid Change
- My review of the 4.083 Final Drive Gears
- Transmission Conversion
- Transmission replaced under warranty, now clutch feels weird?
- need help about purchasing a clutch
