View Full Version : Drivetrain
- 3.7 or 3.9 FG?
- Manual trans oil
- Transmission Problem...maybe
- How do you know if the pumpkin is a "3.5" instead of a "3.3"???
- How many miles on your OEM 6mt Clutch and Flywheel?
- Auto to Tiptronic on the fly?
- Clutch Pedal Problem (Low when Hot)
- Shifting to 2nd gear with AC on
- Better Torqe Converter Nessecary?
- AT tranny cooler?
- General clutch warranty question?
- Problem with tranny and coolant
- Anybody do a 5AT tranny fluid flush/fill?
- Automatic transmission
- Strange noise coming from passenger rear...
- 6mt drivers: Clanking noise when stepping on the clutch?
- Warranty cover clutch????żżż
- Clicking From diff
- Clutch and Flywheel Question
- Clutch adjustment
- valve body removal
- Chatter sound coming from gear box?
- repair trans
- 5AT transmission cooler?
- trans problem?
- Clutch pedal sticking with aftermarket:
- short shifter
- Clutch and Flywheel Problem ?
- 6th gear shakes
- what to use in my 03 6mt, and diff... can i use the same stuff???
- LSD questions.
- AT check light flashing (14 times?)
- Help! Auto Tranny slipping bad (wanna buy it?)
- New to 6MT, but is 1st to 2nd i=supposed to be this rough?
- New Clutch Kit
- xtd CLUTCH and flywheel is this good?
- Flywheel resurfacing?
- swap an auto to a 6MT?? how hard? how much $$?
- click when clutch is disengage
- Quesestion on cltuch/flywheel
- Grinding from 1850 RPM to 2000 RPM auto transmission?
- Click From Pedal When Releasing Clutch
- Pros/Cons of lightweight flywheel?
- The burnout switch mod.
- Open Differential Fluid Change
- Does anyone have problems shifting into 2nd with a SS??
- 6MT Grind, new tranny ordered.
- 5AT owners!
- Has anybody had this problem.... (6MT)
- Replace Clutch G35 Clutch for $2500?!
- New gears
- OS Giken STR installed
- about to buy an exedy stage 1 clutch
- Nismo SS Clutch Line
- 6-Speed in an X...
- Matic-D Matic-J?
- AT Power concerns?
- I Need Fast Clutch Help Please! NY/LI AREA
- Ultimate mod for the coupe:
- 2004 G35X Differential Fluids
- Dealer said to change clutch....
- Dry Shifting???
- Need advice on a clutch purchase...
- Is there a DIY tranny drain/refill?
- Clutch gone bad! Need desperate advice!
- rattling from tranny or clutch?
- 07 vs 06 manual tranny
- having the same ol' problem..HELP!
- Manual Trans Warranty Question
- 5AT tranny slipping??
- new bumper, throw out bearing, and 30K service!!
- For those 5A/T users who have rough shifts
- Crunchy Trans question, engine mod advice, cams
- Need Performance Clutch
- Possible Clutch Problem-Help
- Car wont start after Clutch JOB
- Help: Transmission Problems with my 03 5AT
- Clicking Rear Axle, Have some Questions
- Grinding noise from 1st gear to 2nd gear
- ACT street clutch,ACT prolite flywheel review
- clutch switch
- Braided Stainless Clutch Line users - ?
- 6MT Oil Change?
- LSD, Clutch and exhaust choices
- Urgent! Clutch Install. pedal-return issue
- Too much fluid in tranny
- New tranny just installed
- 3rd Gear Grinding... help!
- dealership quote on clutch/ flywheel
- 5AT drain & fill...
- Car shudders on 2-1 downshift (5AT)
- what clutch and flywheel to get??
- Getting new torque converter what yall think
- Questions before getting new transmission from dealer
- transmission change on coupe
- Transmission question for all you 6mt owners
- Question on grounding wire for 5AT!
- clutch chattering question
- Rear differential fluid change, part 2
- Clutch adjustment on an 05
