- What to do with HIGH millage G35's
- How to reach this goal? 340RWHP and >310LB-FT TQ .
- first oil change soon
- eneos motor oil help
- Serpentine belt replacement
- Oil pan bolt won't come off
- Anyone switch to a bigger oil filter? 07-08 g35x
- my valve cover has a slight leeak ? help .04 g coup
- First time changing oil, Need help ASAP
- my throttle body: clean it now or some other time?
- 1 broken bolt on lower plenum, okay to drive for now?
- Help! Loss of power during high lateral G-force cornering on track
- High Octain Fuel.
- TurboKit
- Mod help please(intake spacer or plenum?)
- What fluids does everyone use?
- Weird issue why car would not start. It was the chipped key!
- guys with 80k miles what type of oil??
- Check this before your powertrain warranty is up!
- 1/4 Mile Performance
- New engine swap has been approved!
- nub here askin about throttle response
- HP vs. Lbs/ft flywheel (torque?) numbers for Stillen SC
- Spring relaeasing sound coming from my car
- HELP! Trey's car won't start! Think it's the starter
- engine torque damper install?
- Exhaust system Help!
- motordyne spacer 1/2 fit??
- Problem with AT! Please Help!
- Need Spacer info.
- The e-Ram Electric Supercharger
- problems with starting my car, battery issue?
- Grounding Kit 7 point 8ga.
- Awesome Twin TB intake manifold 03-07G
- wow! look at these codes!
- 2003 g35c 5AT- something wrong with my G??
- Installed Powerlab 3/8 plenum spacer today
- SLR Motorsports Performance Chip?
- G35 Motors
- What do I need to do to get atleast 400 HP or hopefully over 600?
- OBD2 reading?
- Belt noise on used car bought on Saturday
- Oil Temp: How hot is too hot?
- crackling under car - pinging or something else?
- will it fit? 03 z-tube on 05 coupe
- 2008 6MT Sedan noises
- Problem with GT-SPEC Strut bar, Need help!
- Need Help Have Utec and dead battery!
- Help! Pulstar spark plug problem
- 2K in mods... help me out
- Stillen Engine Torque Damper help!
- High Idle After Cleaning?!
- starting problem...
- power steering fluid
- Vid of my new setup
- Good A** qustion here!!!! plz answer
- Question w/ spacer installation
- My car is slow 6.7 0-60 and 15.00 1/4mi
- battery cover
- AC Problems.. Help...2 big a$s pictures
- HFC and OEM Exhaust
- 06 6MT Coupe Oil Consumption Test is About to Begin
- Which BG cleaner???
- NEED Advice, I'm visiting the Dealer for Repair?
- ANyone
- Help with Y pipe.
- Putting engine cover back on and...
- Built motor for 03 coupe
- TopSpeed Engine Damper
- ecu location
- Doin a Tune-Up
- low pitch engine noise
- Motordyne New Pricing! Cheap!
- need help
- "Diesel" sounding noise
- Speed sensor
- Sprint Booster???
- Master Cylinder Is Growing Algae
- Help with flywheel choice??!!
- Help! Throttle Body Replaced Twice in 2.5 Years / 35k Miles
- help with sending unit right
- Throttle Body Spacer
- How much work to change a tranny on an X?
- Want to Put on new headers??? I'm a Rookie
- G coupe turning off. please help
- cant shift into 6th? help!!
- does the Engine Cover trap heat??
- Help w/ MD plenum Spacers????
- tiptronic question
- Need advice on clutch issue
- Newbie
- Top Speed Engine Damper Install?
- Service Engine Light
- What do u think of my new setup???
- G Won't Start - - Please Help
- Gas pedal limiter block?
- DTC P1238 - what does this mean?
- More Power on Budget
- Idle Air Volume Learning - The car does not remember after a restart!
- ses light code p1084 HELP!
