- Too much air, not enough fuel???
- a little help with the oil
- engine belt
- Barb to -AN Fitting
- Need help URGENT! A/C Pressure Switch problem.
- Whats a good ECU?
- Oil leak from valve covers?
- Which cams?
- fuel tank equalizer tube
- Raditor hose came off
- whats the difference between the different spacer sizes?
- Problem with the rpms. Engine cutting off. Help!
- Problems starting the car?
- Nissan vs Inifnity Dealership for parts, is Nissan cheaper?
- Fan behaviour, can someone please confirm
- Mrev 2
- MD 5/16 iso copper installed, performance dropped!!
- Gains: Advancing Timing
- Has anyone had oil issues with automatic models?
- 5/16" vs 1/2" spacer with Osiris
- What's causing this noise?
- Speed
- Belt/Engine Squeaking
- 6+ hours in the garage this weekend...DIY...
- engine knock
- radiator/ac condenser fan, are both suppose to spin?
- Gauge pod
- PCD Performance Chip Stage 1? wtf,
- Sounds like firecrackers under my car over 45 MPH? WTF!
- need help quick! Is a oil catch suppose to suck in air?
- G35 motor
- Bank 1 and bank 2 question?
- Good books
- Oil Consumption & Glendale Infiniti
- Question on auxilary fan in 03 sedans - want to do electric fan conversion.
- 5th Gear/Syncro Problem
- help with nos!!
- Is this exhaust legitimate?
- What is wrong clutch ,release bearing??? can't get it to gear
- a/c gradually blows cool air then hot!
- IPDM Getting Wet - Common Issue?
- Pinging/Knocking
- need help!!
- Pinging reduced with higher octane (revup owners only)
- What kind of clutch to buy
- Slight "rythmic" vibration/noise.
- 2005 g35x service engien soon, plz help
- 2004 coupe engine completly shot
- 2004 6MT Sedan wont' start --- thoughts??
- JDM G35 turbo'ed?
- Engine Hesitating in low gears - please help!
- Odd Engine Feel
- Can I use a UTEC from a WRX/STI on my car?
- Plz help...possible bad rings?
- Try just resetting ECU before buying a grounding kit
- VSS module location?
- whistle noise
- 06 MT Oil Consumption.
- Need Help! - CF Intake Tube
- kinetix plenum
- WTB 2005 REV-UP Long Block
- Spark plugs
- heater issue after coolant change
- Anyone paint the OEM engine cover?
- 5/16 spacer question
- NorthEast Turbo Install
- Which Engine Oil good for 2003 G Sedan
- Valve body upgrade. 5at cheapest place to buy it?
- Will sedan radiator fit coupe
- Steering is harder!
- Ark Grip Exhaust Installed--Pics
- Camshafts and Vavle Springs
- are my radiator fans acting up?
- Which Plenum spacer should I buy??
- where to get J matic besides dealer??
- how can you tell if the fan in your engine bay is out?
- Engine stalls on deceleration ?!?! Anyone else had this problem ?
- master slave cylinder question
- hows this gonna work out?
- Knock sensor code
- why does my G engine temperature idle at HOT?
- Unorthodox racing pulleys... YES or NO
- Speedo, Tach, VDC/Slip lights, etc. malfuctioning
- Chevron Motor oil 10w-30?? - Nissan service falsely told me 4 different brands of oil
- How does variable valve timing work?
- Auto transmission question
- Difference in VQ35DE motors??
- 04 G35 Sedan: Engine knocking/clicking problems...help?
- Junkyard VQ35DE
- Strange situation in neutral
- Nismo Cams ~ worth it?
- RPM's climb off throttle
- Oil Consumption in a 03 sedan AT
- Anybody use Prestone Super Radiator Cleaner?
- gas tank needle not reading
- Oil consumption and new engine
- Experienced some weird slippage
- Burning oil this morning
- ECU - Swappable? How?
- Cammed G35s?
