- change my oil every 10k miles?
- 6MT dies when in gear & clutch let out. Blows "IGN CONT ECCS" fuse
- '06 G35 Auto Sedan - New Engine After 60k.. Will my baby ever be the same again?
- Redline MT-85 Transmission Fluid Review
- DIY Cam Position Sensor Easy Version
- P0011 Camshaft sensor code + low oil indicator
- 2005x burning oil
- ******Fuel return help please*******
- Confusing 06 G35x Alt/Ps Belt Size Disrepency
- p0335, no spark, new sensor
- Rev-up heads/non-rev-up block?Help!!
- need some help/advice
- AC Belt
- people with aftermarket powersteering tank
- ***** Help!!!! Wire tuck on TT set up ******
- Hesitation when Acceleration
- zeitronix zt-2 and zr2 install question
- Rebuilding an alternator?
- ***I will never deal with aam again!!*****
- Tomei Test Pipes?
- Should this Hole be in my Airbox?
- diy hood damper/hood strut mod
- New Alternator and Alternator Charger Wire Questions???
- SPAL PWM fan controller install-need help
- Ignition Question after failed alarm install.
- Goodbye ARC [ARC International Bankrupt]
- G35 Auto trans swapped with 350Z Auto Trans,car has no power
- Grinding under hard acceleration
- My Fuel Mileage declined after mantenance??
- Overheating Issue
- 2008 Random Stalls
- CRANKshaft position sensor location (NOT Camshaft)
- Bad Camshaft Position Sensor on '06
- Long Cranking time
- Ticking noise under acceleration
- G35 Coupe Radiator Core Support...
- noob needs help with idle
- How to know if i have a "rev-up" motor. Please read
- DS mode?
- Im so new to this!!! NEED HELP!!!
- Idle and Stalling problems after mrev installation
- I need a new ENGINE. NorthEast Jerz
- Engine makes pinging/ticking/knocking noise. Engine has burning smell, and shakes!
- Can oil catch can hose length cause issues?
- noisy engine fan on my g35!
- DIY Nissan Murano spark plug tube seals
- I just installed Megan testpipes and... CHECK ENGINE LIGHT!! HELP
- Pressure testing w/Turbonetics ST kit
- please HELP!
- need help with exhaust install pleaseeeee
- turbo Kit
- Is this guy full of it?
- Timing cover bolt lenght and sizes???????
- Oil in plenum
- VQ35 Tech info about models and internals needed please!
- Why Fram Oil Filters Suck
- 2004 6mt shot trans 79K miles
- P2A00 and P2A003 Code Please help
- My g35 05 sedan noise
- HELP! Car doesn't want to start randomly
- DIY AC compressor tensioner pulley
- VQ35 Engine VIN Location?
- Engine Loses power - Test Drive Gone Bad
- 05 twin intake
- Radiator Rubber Mounts
- RPM needle bouncing upon start. Help
- Do we have the same radiator cap as 350Z?
- Drive Belt Replacement
- Several issues with my g
- Code from ECU PO507
- 350z mid pipe help question???
- x pipe test pipe help!!!!
- o2 sensor brand recomendation
- DIY valve cover replacement. Again
- engine noise ? light high pitched rattling from serpentine belt system ????
- Gauges suggestions
- Leaking coolant, water pump, timing chain tensioner.
- Cold Starts= idles at low rpm?
- Bosch O2 Sensor and P1273 Code
- Started out replacing clutch...Suggestions please...
- Help with a small rattle from the engine.
- Video of car burning oil.
- Right Code, Wrong Description?
- Help. P0037 error code
- p0132 & p0152 codes, rough idle when cold
- UTEC MAP vs MAF
- is there possible to installation
- best place to buy oil & oil filter
- Urethane transmission mount on automatic?
- 8 rib surp belt upgrade
- the_coupe's NA engine build thread
- bc valve springs
- 103 K miles should i get my transmission fluid changed???
- Car will not rev up!!!!!
- Do I need this hooked up?
- DS Mode shifts Down but not UP Help
- consuming oil
- ??????? about front wheel bearings
- to build or not to build.....
- Car problems!
