- i need more power
- Rev-Up/Non-Rev Up Lower Plenum
- 03 g35 oxygen sensor??
- Fan belts crack/glaze at 24k miles?
- P0021 Intake Valve Timing Control ..bad news?
- Gas Milage Vs. Oil
- upgrade advice please.
- HELP: full of oil in spark plug hole
- Short Vid of my Baseline Dyno Run.
- Reading & looking up self diagnostic flash patterns
- blew my motor....parts help
- If I add a K&N filter...
- wideband
- Dont Buy This!
- Heat problem
- Car almost stalls waiting at lights, or when stopped
- Swapping the 03 g35 engine for a revup one
- Switching to Motul engine oil at 30K?
- Where can I get this part?
- Looking for the Best Shop
- Oil Consumption
- 2004 G35X wouldnt start and engine flooded HELP!
- Engine Knock after sitting for a week
- all warning lights turn on in speedometer..
- Anyone with 2 greedy remotes switchs??
- is this a problem?
- Lots of oil in spark plug tube area (video)
- Car is having issues 04 g35
- Flashing / Blinking Service Engine Light
- A Z owner saying the Z has a different tune and requires Prem when the G doesn't
- Rattling sound heard from engine bay
- Power Steering Not Working
- Odd sound after HFC and Y-Pipe install...
- Engine sounds like a waterfall?! Help!!
- problem with heater
- Oil Consumption in a 2003 5AT???
- SES light - P0171 & P0174
- Oil filter part # - 15208-9E000 instead of 15208-65F00
- who here is still using dino oil on their G35?
- What does "Rev-Up" engine mean as in the 2005-2007 G35 engines
- Need some new battery advice!
- got my stillen ztube today
- Questions about the MREV2
- Shifting problems in Auto 2004 G35 Coupe
- G35 Coupe Aftermarket RAdiator? ? on Oil pressure
- Mishimoto Radiators
- Spark plug indexing... a waste of time???
- Performance Factory 07 Twin Turbo G35
- Haltech
- oil pan install (pics)
- Which Is The Best Bolt On For Power??
- nothing but problems......................
- check engine / 5 cylenders
- Anyone know someone that will do custom cam grinds for vq35
- Why Is My Car Slower??
- Oil Light Question
- Why Does My Car Keep Dying?!
- Engine pinging has become an issue as of late.
- spacers
- Chips
- 350evo SSK or 5/16 iso thermal spacer?
- Anyone Teflon coated their Intake?
- Brand new engine knocking at 300 miles!
- power steering question
- afe intake for the G. Does anyone have this?
- What short shifter is this??
- engine oil
- Ok....i think i have a problem.
- Question on OEM Infiniti radiator cap and aftermarket cap
- UR Pulley Install Q
- After I/H/E what's next?
- Sound clip wanted: stock coupe exhaust w/ no cats
- After I/H/E whta's next?
- weird engine sound
- Simple Engine Question
- how long has your battery lasted ?
- 2J Swapped 350Z.....
- engine help?
- Coolant Leak question
- Grinding noise when starting the engine
- steering vibration of my car, help guys??
- Recommended oil for '04 G35 Sedan?
- DTC P1229, elaborate
- Annoying problem when i start the car
- HELP!! chattering sound coming from ENGINE
- V8 conversion for a G coupe....
- Vehicle won't rev above 2200rpm, dealer couldn't replicate
- Unusual engine rev when braking
- MDE Iso Thermal 5/16 Spacer 350z -> G35c Fitment
- 2003 G35 Recall for Cam Sensor... But it occured already..
- autosport harness is this a good deal
- Is that a catch can, or are you just happy to see me?
- Check engine light on after MREV2
- Idler Pulley Removal Mod with Pics
- Bad water pump? '03 sedan
- Service Engine Soon?!
- Has anyone had this problem??
- Mobil1 Extended Performance 15000 mile gar.
- 5k miles on royal purple
- FI Sedan with rev limit problem...
