- JWT 700bb dyno charts
- Question about shifting...
- engine or transmission problem?
- Castrol Edge and blackstone labs question
- AC7M9 V2 info anyone?
- md plenum spacer help!
- would nismo cams fit on a g35?
- My tranny rattles like a mofo
- Nissan parts for coolant change?
- when engine is under load it sounds like valves are ticking/rattling
- Drove through water...trouble...please advise
- NEED MORE TorQUe
- Help-Trouble Starting Engine
- Performance mods for a 5AT? Worth it?
- Problem!
- a couple short ram questions
- 5 quarts for diff and gear?
- Yet Another Motor Oil Thread
- After ECU reset, what needs to be done regarding OBD2 before smog
- transmission syncro problem
- z tube help
- Aftermarket oil cooler question
- bad or good decision on my order?
- is an AT coupe worth modding for power?
- Infiniti says cars sound is from the purge valve solenoid?
- Fluid Amounts Required for changes
- HELP!!!! Car keeps stalling!!!!
- Blew Engine On My G less than 48 HRS!
- Car Stalls Help!
- i think my car died at 20mph
- Analysis of the 335 and G37 (warning, math heavy)
- Weird Sound, sounds like a turbo~!
- AccessTUNER for Nissan/Infinity available NOW!
- supporting mods for FI
- The next upgrade (advice needed)
- UR Pulley's
- Test Pipes making the car limp : (
- Question - Leak in driver's footwell
- QUESTION: which is better DO full bolt on or save for Vortech S/C FOR MORE HP?
- HKS Ti exhaust tips
- Help finding Headers
- Got beat bad by a stock 350Z!, Any ideas why?
- too many miles for synthetic oil?
- Replacing Spark Plugs
- Wife's G35... VDC Off, SLIP, and Service Engine Soon Lights All On!
- transmission problems
- Engine Heating Issue?
- Starter question
- Crank pulley
- Clutch problem
- Overheating Light On, but temp does not rise?
- car overheats when a/c is running, is it my ac/condenser fan?
- are the fans in front of the radiator all universal for 03-07 models?
- whats a charcoal air/in cabin filter?
- Need help with Cylinder Head compatibilty!
- Hard to turn steering wheel
- Quick Tranny Fluid Drain Fill Question
- noisy idler pully
- timing belt went? tech help.
- Rev Limited Question
- Mrev 2 explaination
- Someone explain the RevUp thing to me
- who knows about VDC??
- Good article on WPC coating
- pulleys with vortech
- Pulstar spark plugs ??
- Variable Valve Timing Question
- VIDEO - Engine Pinging
- Detachable spark plug gaskets?
- Revshift Poly Engine Mounts. Love the mount, hate revshift.
- Original Spark Plug?
- Mod Suggestion 04 6mt
- Which Gives Better Performance? Ztube+K&N Drop in or Ztube+PopCharger?
- Which mods of the coupe fit the sedan?
- Anyone having problems
- Question about oil type....
- SxExCx Custom Grounding Kit...with a twist!
- Tires, rear differential fluid...
- NGK iridium plugs
- narrow band o2 sensor swap to wide band
- New clutch install chatter questions?
- what tells the ac/condenser fans to spin up?
- P0430 AND P2135 code..???
- Going to be a good mod weekend
- Clutch-Starter safety feature location?
- help with do-it yourself transmission rebuild or just go with dealer
- Clutch falling Halfway to the floor
- Which Pulley Set
- Engine operating temps, what's yours?
- Crazy misfire, came overnight, so confused.
- Spark Plug Reccomendations
- Motordyne 5/16 vs. AAM angled spacer
- Help engine problem
- AUTOMATIC Rev-up vs Non-revup AUTOMATIC
- does more refined gasoline burn faster resulting in a low mpg?
- Why does SLIP come on
- hard stop safety feature?
- Ticking sound in dash
- Utec, Uprev, or unichip which one?
